Lutron Binding : Error scanning for devices
I have a Lutron Lighting system in my home which I openhab successfully connects to and controls…for a while. Then it just dies. I’m getting this in my openhab.log file. Does anyone have any advice on how to fix this.
My luton.items file looks like this:
Dimmer Chandelier “chandelier” [ “Lighting” ] { channel=“lutron:dimmer:chandelier:lightlevel” }
Dimmer KitchenCans “kitchen” [ “Lighting” ] { channel=“lutron:dimmer:kitchen:lightlevel” }
Dimmer GreatRoom “front” [ “Lighting” ] { channel=“lutron:dimmer:greatroom:lightlevel” }
Dimmer TheaterFront “movie front” [ “Lighting” ] { channel=“lutron:dimmer:theaterfront:lightlevel” }
Dimmer TheaterRear “movie back” [ “Lighting” ] { channel=“lutron:dimmer:theaterrear:lightlevel” }
Dimmer MasterBed “master” [ “Lighting” ] { channel=“lutron:dimmer:master:lightlevel” }
And lutron.things file:
Thing lutron:dimmer:chandelier (lutron:ipbridge:b993da2d) [ integrationId=9, fadeInTime=3, fadeOutTime=3 ]
Thing lutron:dimmer:kitchen (lutron:ipbridge:b993da2d) [ integrationId=10, fadeInTime=3, fadeOutTime=3 ]
Thing lutron:dimmer:greatroom (lutron:ipbridge:b993da2d) [ integrationId=7, fadeInTime=3, fadeOutTime=3 ]
Thing lutron:dimmer:theaterfront (lutron:ipbridge:b993da2d) [ integrationId=15, fadeInTime=3, fadeOutTime=3 ]
Thing lutron:dimmer:theaterrear (lutron:ipbridge:b993da2d) [ integrationId=14, fadeInTime=3, fadeOutTime=3 ]
Thing lutron:dimmer:master (lutron:ipbridge:b993da2d) [ integrationId=5, fadeInTime=3, fadeOutTime=3 ]
2016-09-21 07:48:32.572 [ERROR] [scovery.LutronDeviceDiscoveryService] - Error scanning for devices
com.thoughtworks.xstream.io.StreamException: : ParseError at [row,col]:[1,1]
Message: Content is not allowed in prolog.
at com.thoughtworks.xstream.io.xml.StaxReader.pullNextEvent(StaxReader.java:73)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:148)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:141)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.AbstractPullReader.move(AbstractPullReader.java:118)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.AbstractPullReader.moveDown(AbstractPullReader.java:103)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.StaxReader.(StaxReader.java:45)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.StaxDriver.createStaxReader(StaxDriver.java:173)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.io.xml.StaxDriver.createReader(StaxDriver.java:110)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1115)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1062)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at org.eclipse.smarthome.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:82)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService.readDeviceDatabase(LutronDeviceDiscoveryService.java:84)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService.access$0(LutronDeviceDiscoveryService.java:80)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService$1.run(LutronDeviceDiscoveryService.java:67)[200:org.openhab.binding.lutron:2.0.0.b4]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_31]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_31]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_31]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_31]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_31]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_31]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_31]
Caused by: javax.xml.stream.XMLStreamException: ParseError at [row,col]:[1,1]
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:601)[:1.8.0_31]
at com.thoughtworks.xstream.io.xml.StaxReader.pullNextEvent(StaxReader.java:58)[95:org.eclipse.smarthome.config.xml:0.9.0.b1]
… 20 more
2016-09-21 21:21:16.070 [ERROR] [nding.lutron.handler.IPBridgeHandler] - Communication error, will try to reconnect
java.io.IOException: Could not write to stream
at org.openhab.binding.lutron.internal.net.TelnetSession.writeLine(TelnetSession.java:218)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler.sendCommands(IPBridgeHandler.java:196)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler.access$2(IPBridgeHandler.java:188)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler$3.run(IPBridgeHandler.java:174)[200:org.openhab.binding.lutron:2.0.0.b4]
2016-09-21 21:21:16.084 [ERROR] [nding.lutron.handler.IPBridgeHandler] - Error disconnecting
java.net.SocketException: Socket closed
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:116)[:1.8.0_31]
at java.net.SocketOutputStream.write(SocketOutputStream.java:153)[:1.8.0_31]
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)[:1.8.0_31]
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)[:1.8.0_31]
at java.io.FilterOutputStream.close(FilterOutputStream.java:158)[:1.8.0_31]
at org.apache.commons.net.telnet.TelnetClient._closeOutputStream(TelnetClient.java:86)[177:org.apache.commons.net:3.2.0]
at org.apache.commons.net.telnet.TelnetOutputStream.close(TelnetOutputStream.java:155)[177:org.apache.commons.net:3.2.0]
at org.apache.commons.net.telnet.TelnetClient.disconnect(TelnetClient.java:127)[177:org.apache.commons.net:3.2.0]
at org.openhab.binding.lutron.internal.net.TelnetSession.close(TelnetSession.java:116)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler.disconnect(IPBridgeHandler.java:233)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler.reconnect(IPBridgeHandler.java:243)[200:org.openhab.binding.lutron:2.0.0.b4]
at org.openhab.binding.lutron.handler.IPBridgeHandler.sendCommands(IPBridgeHandler.java:204)[200:org.openhab.binding.lutron:2.0.0.b4]
squishy:logs Michael$
Did you ever find a solution to this? I get the same thing
I hacked the code to fix it. Are you a coder? I could send you the fix.
not necessarily a coder but I’d like to take a look if you be willing to share
Sure. I have access to the code next week again. I’ll send it to you.
Mike
I am also having the same issue and would love to find a fix.
Hi
Here’s the change I made to this file: LutronDeviceDiscoveryService.java
Note the getNoPrologURL method. The problem it gets around is that the xml
from Lutron
has a prolog that begins <?xml. The framework can’t handle that
apparently. I haven’t looked at this for months so I can’t help you much
other than that. You could give this to the author or submit a patch.
Maybe with the problem very concisely explained someone actively working in
the framework could integrate it for you too.
good luck.
Mike
  • Copyright (c) 2014-2016 by the respective copyright holders.
Hi. It’s been quite a while since this thread was started, but I wanted to add a quick note. Looking back at the original stack trace, it looks to me like this was actually two separate problems with the binding: one in LutronDeviceDiscoveryService that resulted in an XML parsing error while attempting periodic discovery, and one in IPBridgeHandler that caused the binding to stop working in some cases when communication with the bridge device had been interrupted. This second problem was fixed in the 2.4.0 code in PR #4056, and the fix is now available in 2.4.0 M6.
I haven’t run in to the LutronDeviceDiscoveryService XML parsing error myself, but I’m interested in trying to get your fix for that merged in to the code as well. Unfortunately, it looks like the post containing it was truncated right before the important bit!
Bob
This is an old thread, but I recently added my lutron devices, they work great (I had to manually add them). I cannot auto discover the things (I have switches, dimmers and remotes), and I have this entry in the log.
I want to know what I’m doing wrong…Any help?
13:38:44.500 [ERROR] [iscovery.LutronDeviceDiscoveryService] - Error scanning for devices
com.thoughtworks.xstream.io.StreamException: : Connection timed out (Connection timed out)
at com.thoughtworks.xstream.io.xml.StaxDriver.createReader(StaxDriver.java:126) ~[101:org.eclipse.smarthome.config.xml:0.11.0.oh250M1]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1115) ~[101:org.eclipse.smarthome.config.xml:0.11.0.oh250M1]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1062) ~[101:org.eclipse.smarthome.config.xml:0.11.0.oh250M1]
at org.eclipse.smarthome.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:85) ~[101:org.eclipse.smarthome.config.xml:0.11.0.oh250M1]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService.readDeviceDatabase(LutronDeviceDiscoveryService.java:92) ~[218:org.openhab.binding.lutron:2.5.0.M1]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService.access$0(LutronDeviceDiscoveryService.java:88) ~[218:org.openhab.binding.lutron:2.5.0.M1]
at org.openhab.binding.lutron.internal.discovery.LutronDeviceDiscoveryService$1.run(LutronDeviceDiscoveryService.java:75) [218:org.openhab.binding.lutron:2.5.0.M1]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at java.net.Socket.connect(Socket.java:538) ~[?:?]
at sun.net.NetworkClient.doConnect(NetworkClient.java:180) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558) ~[?:?]
at sun.net.www.http.HttpClient.(HttpClient.java:242) ~[?:?]
at sun.net.www.http.HttpClient.New(HttpClient.java:339) ~[?:?]
at sun.net.www.http.HttpClient.New(HttpClient.java:357) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1220) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1156) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1040) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1038) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1037) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:984) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1484) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1482) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1481) ~[?:?]
at java.net.URL.openStream(URL.java:1045) ~[?:?]
at com.thoughtworks.xstream.io.xml.StaxDriver.createReader(StaxDriver.java:109) ~[?:?]
… 13 more
Mike Schultz mike.schultz@gmail.com
Jan 6, 2018, 1:35 PM
to openHAB
Hi
Note the getNoPrologURL method. The problem it gets around is that the xml from Lutron
has a prolog that begins <?xml. The framework can’t handle that apparently. I haven’t looked at this for months so I can’t help you much other than that. You could give this to the author or submit a patch. Maybe with the problem very concisely explained someone actively working in the framework could integrate it for you too.
good luck.
Mike
Sorry to insists, but I cannot find that file. I’m running openhab2 on ubuntu 18.04. Can you please be more specific?
Sorry. I only know what i did 2ish years ago which was modify a Java file and recompile and deploy the jar. Haven’t touched since.
Mike
Hi Algis. Which Lutron system do you have? Auto-discovery should currently work with Radio RA2 and (probably) HomeWorks QS systems with newer software versions. It will not currently work with Caseta or older HomeWorks QS software versions. Those still need to be configured manually. If you have a Caseta system, then that “Error scanning for devices”/"Connection timed out " error in your log is expected, and you can just ignore it.
I’m currently testing an update to the discovery code in the Lutron binding that will eliminate that error on Caseta systems, allow auto-discovery of Caseta bridge devices via mDNS (but not yet the attached devices), and allow auto-discovery of older HomeWorks QS systems, among other things. I’m hoping to get it in to 2.5.
Hi, I have caseta dimmers and sewitches and the Lutron Pro 2 hub.
Ah, ok. You can just ignore that error in your logs, then. It should go away in the next version.
Excellent, thank you.
