I ran into a problem this morning. I tried to add the Lutron Binding in the Paper UI and lost just about everything.
When I go to the main OH page Habpanel, Habmin is gone. Even when I look to see my bindings in Configuration Bindings of the Paper UI there is nothing there.
What did I do and how can I fix this please.
So this is what I get in my log reports when I try to install the Lutron Binding in the Paper UI.
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
Caused by: java.util.zip.ZipException: invalid CEN header (bad signature)
at java.util.zip.ZipFile.open(Native Method)[:1.8.0_101]
at java.util.zip.ZipFile.(ZipFile.java:219)[:1.8.0_101]
at java.util.zip.ZipFile.(ZipFile.java:149)[:1.8.0_101]
at java.util.zip.ZipFile.(ZipFile.java:163)[:1.8.0_101]
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:288)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
… 80 more
2017-01-03 11:50:00.721 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-lutron’: Unable to update bundle
2017-01-03 11:42:07.568 [ItemStateChangedEvent ] - IndoorSensor_CO2 changed from 992.00 to 1005.00
2017-01-03 11:42:07.577 [ItemStateChangedEvent ] - IndoorSensor_Temperature changed from 19.10 to 19.00
2017-01-03 11:42:07.580 [ItemStateChangedEvent ] - IndoorSensor_Noise changed from 37.00 to 34.00
2017-01-03 11:42:07.584 [ItemStateChangedEvent ] - IndoorSensor_Pressure changed from 1008.80 to 1008.70
2017-01-03 11:49:30.639 [hingStatusInfoChangedEvent] - ‘netatmo:NAMain:53cccd0e:70ee5019e1d4’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-03 11:49:30.649 [hingStatusInfoChangedEvent] - ‘netatmo:NAModule1:53cccd0e:02000019b542’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-03 11:49:30.660 [hingStatusInfoChangedEvent] - ‘netatmo:netatmoapi:53cccd0e’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-03 11:49:30.888 [hingStatusInfoChangedEvent] - ‘zwave:device:1a57dc86:node3’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-03 11:49:31.044 [hingStatusInfoChangedEvent] - ‘zwave:device:1a57dc86:node2’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-03 11:49:31.154 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:1a57dc86’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
