We have a RadioRA2 system that I have taken over from the original electrician. RadioRA2 Essentials reports all integration IDs up to 119. But the OpenHab Lutron binding discovery process found an additional device with ID 120. It has a name that was obviously set correctly “…driveway pillar lights” but shows up as status “Unknown - awaiting initial response”. I have done a fresh “Extract” from the main repeater into a new project file, but still device 120 doesn’t show up.
If the main repeater doesn’t know about this device by name, how can it show up in discovery with a name and ID? How could it even get named in the first place other than through the process of adding it in the design software? And how can I connect to it? I’m worried that the actual switch (which I cannot find physically) was installed at the end of the driveway, where the lights are, instead of in the house where the circuit is. In which case am I out of luck contolling them? What’s weird is that they are apparently on a timer, because they go on and off! Maybe the timer is outside RadioRA2 altogether (ouch!)…
Thanks for any help!
