Hi @sgiehl
Yes, my software version is V3.85.5 (r6309).
I downloaded your luxtronikchannels branch and can confirm that channel 257 (PowerActualValue2) contains the values I’m expecting.
After only a few hours in use, I can’t confirm much, but here’s what I have:
Background data:
- outside temp overnight +/- 10 (heat pump is outside)
- minimum hot water temp 40
- maximum hot water temp 50
Channel 232 - data values +/- 100 when warm water is not being generated, +/-10 when warm water is being generated, spikes to -115 when generation starts (
Channel 233 - data values +/- 97 when warm water is not being generated, just to 320 when generation starts, slowly increases to 480 when generation is finished and then drops back to +/- 97 - probably a return temperature in the heat pump
Channel frequencyCompressorTarget (236) - data value always 0, jumps to 3000 when warm water generating starts, spiking 10 minutes later to 3250, immediately drop to 2950, then continually increasing to 3250 by the end of the generation, immediately dropping back to 0 when generation finished
Channel 237 - data value always 0 when warm water is not being generated, spikes to exactly 50 when heating starts, then drops immediately to exactly 30 until heating finishes
Channel 238 - data value always 0 when warm water is not being generated, jumps to exactly 100 when heating starts, spikes to exactly 115 when heating finished, then drops immediately back to 0
Channel 244 - data value always exactly 600
Channel 249 - data value generally sinking from 260 to 180 when not heating, goes up steeply when heating starts, then still up but slower until heating finishes, topping out at 440, after heating stop drops steeply to around 260, then generally sinking - probably a temperatur
Channel 250 - similar to 249
Channel 251 - data values are generally rising from -150 to -90 when not heating, spikes to 75 when heating starts then +/-35 until heating finishes, spikes to -240 then increases fairly quick to -150, then generally rising again - interesting data pattern, but I can’t figure out what this one could be
Channel 252 - data values exactly 900 when warm water is not being generated, jumps (almost) immediately to exactly 1150, while generating, dropping immediately and exactly back to 900 afterwards
Channel 256 - data values always exactly 5
Channels with no data (always 0) - 234, 235, 239, 240, 241, 242, 243, 245, 246, 247, 248, 253, 255, 258, 259
If I can help further, please let me know
