I just ordered a m5paper, which is basically an m5stack with epaper touch screen (esp32-powered), to build an control panel to display sensors and manage simple actions.
Until it makes its way home, I’m thinking about the software part :
Since it’s rather recent, there’s not a lot of software already compatible.
I’m considering porting existing software to use the epaper display, rather writing something from scratch.
Except HomePoint, I have not found a lot of esp32 software to be used as a panel… (HomePoint is MQTT-based).
My question is : do you have similar esp32-based panel setup ? Which solution, other than HomePoint, should I consider ?
