I’m running two different OH3.2 system, with the latest upgrade, which have now the same error.
Mail which should send out triggered by a rule will not more send to SMTP.WEB.DE mail server.
The error which I can see in the logfile from OH3 is the following:
I have arround 30 such of scripts running for everything. Temperature in room above ABC, or xyz switch on, etc.
Here is the line which will be triggert as an example:
val mailActions = getActions(“mail”,“mail:smtp:6cd5aa89af”)
mailActions.sendHtmlMail(“jochxxxx.schxxxxxxx@xxx.de”, “Es hat im Garten zu regnen aufgehört.”, “Im Garten hat es gerade zu regnen aufgehört.”)
So nothing special.
And as said before. Mail sending has been working since 1/2 year now without a problem.
o.k., if it worked before then this is odd somehow… I think the issue is on OH sender side, the mail has not yet really been sent at this point.
Does it work if you use sendMail instead of sendHtmlMail, as then there is no multipart required?
