Main UI: Chart Page - x Axis Resoultion
Hello all,
i am currently working on a chart page in OH3 Main UI.
I want to display the humidity of several rooms over 1 day (or last 24h …).
However i am always getting a very zoomed out display of the lines, independent what i select in Chart Type. Also the history values are always cut on the left side of the chart.
I just want to have a full size display of the values over the last day.
Can someone give me a hint? :slight_smile:
For example Chart Type = Day:
Or Chart Type = Dynamic period Initial Period = D:
This is my current code of the page:
  label: Luftfeuchtigkeit
  sidebar: true
  visibleTo:
    - role:administrator
    - role:user
  period: D
slots:
  grid:
    - component: oh-chart-grid
      config: {}
  xAxis:
    - component: oh-time-axis
        gridIndex: 0
  yAxis:
    - component: oh-value-axis
        gridIndex: 0
        min: "0"
        max: "100"
  series:
    - component: oh-time-series
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: XiaomiKlimaSensor4_Luftfeuchtigkeit
        name: Luftfeuchtigkeit Kinderzimmer
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: XiaomiKlimaSensor3_Luftfeuchtigkeit
        name: Luftfeuchtigkeit Wohnzimmer
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: XiaomiKlimaSensor1_Luftfeuchtigkeit
        name: Gelüftet Kinderzimmer
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: bar
        item: LueftenIstMarie
        name: Gelüftet Wohnzimmer
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: bar
        item: LueftenIstWohnzimmer
  legend:
    - component: oh-chart-legend
        show: true
        orient: horizontal
  dataZoom:
    - component: oh-chart-datazoom
        show: true
        type: slider
        orient: horizontal
  visualMap: []
  tooltip:
    - component: oh-chart-tooltip
        show: true
        orient: horizontal
As far as I can tell, there is nothing wrong with the page code. It looks more like a persistence issue; the data simply aren’t there. What is your persistence configuration? Charting only works with the default persistence, I believe; it cannot access the data in a secondary db.
