Main UI Web Audio
Since upgrading to openHAB3, I started using the main UI instead of habPanel. What I am missing is the web audio functionality. Can anybody confirm that web audio is not available in main UI or am I doing something wrong?
The console shows web audio as default sink, but I can not hear anything on my device which formerly worked flawlessly with openHAB 2 and habPanel:
openhab> openhab:audio sinks
  System Speaker (enhancedjavasound)
* Web Audio (webaudio)
same to me.
I have habpanel running in a 2nd tab of my browser. Works even though MainUI is visible.
But it needs to be a tab in the background, not a separate brwoser in background
Although the docs state that UI would support WebAudio this Issue is Open.
Okay, thanks for pointing out the issue. I am going to follow progress there.
It seems the issue is still open. @vbier Have you found any other option/workaround to play sounds in habpanelviewer using the OH3 GUI?
Nope
I there still a problem with webaudio?
I can’t get it working on OH 4.1.0
kind of…
I noticed that you have to do one interaction with the GUI before web audio connection is established. Apart from that it works on an android/chrome connection. I haven’t tested other clients yet.
