I want to create rules which do different things based on the brightness my weatherstation delivers.
Working quite fine but I already knowed that I will have a problem while I was writting the code… but currently it doesn’t make “click” for me to find a solution for it. I bet it’s absolute easy so sorry for asking but it won’t come to my mind
First rule turns on a light based on the brightness level. Second rule turns the same light off based on time (which is the way I would like to have it). So after light was turned of by the time trigger the light goes on again. Of course this is because first rule turns it on again because a change happend and brightness is still lower than 500.
rule "Dekobeleuchtung Flur an Dämmerung"
Item Daemmerung changed
if (Daemmerung.state <= 500){
sendCommand(EG_Flur_DekoLicht, ON)
rule "Dekobeleuchtung Flur aus"
Time cron "0 55 21 * * ?"
sendCommand(EG_Flur_DekoLicht, OFF)
What do you suggest to get the rule not turning on the light again for today after it turned out by the second rule.
Second thing is. That if the brightness goes below 500 after the time defined in rule two the light should not turn on. What do you suggest? I would use a “if” checking with “gettimeoftheday” and only let it run if time is lower as time of second rule. Other / better ideas?
In the first rule, check that the time is before 9:55pm. You can either check the current time or use another Item and rule that will let you know the light should not be on (search for Time of day). This only handles one room though, so you may want to expand to your whole house…
import java.text.SimpleDateFormat
import java.util.Date
var dt = new DateTime().getMillis()/1000 + 60 * 60
val SimpleDateFormat sdf = new SimpleDateFormat("HH:mm")
val String strTime = sdf.format(new Date())
if (Daemmerung.state <= 500 && strTime < "21:55" ) {
Or, since Joda is removed in OH 3.0, compare using ZonedDateTime…
val zoneddatetime_now = new DateTimeType().zonedDateTime
if (Daemmerung.state <= 500 && zoneddatetime_now.isBefore(zoneddatetime_now.withHour(21).withMinute(55))) {
EG_Flur_DekoLicht.sendCommand(ON)
