I have a page that generates a list of all switch items in a group in a oh-list-card by using the oh-repeater to display a oh-toggle-item for each switch.
The problem is that i have to exactly press the toggle, pressing the whole item row does not interact with the switch. Is there a way that allows to make the whole row to interact with the switch?
I have a lightswitch widget, which toggles a group of lights bij pressing the whole “button” and seperate buttons for in/decreasing the dimmer.
Here is a “piece” of code that contains the clickable part of the button.
It basically involves making a oh-link inside a oh-link. Not sure if this is what you are looking for. You MIGHT be able to do the same trick with the oh-toggle-item part, but I haven’t done that one before.
- component: f7-block // Container for the button
style:
margin: 0 0
padding: 0px 0px
flex: 3
display: flex
flex-flow: row wrap
justify-content: center
align-items: center
border-radius: 20px 0px 0px 20px
slots:
default:
- component: oh-link // The clickable container for the button which actually toggles the item (light) in question
action: toggle
actionItem: =props.item_switch
actionCommand: toggle
style:
margin: 0 0 0 0
padding: 40px 0px
flex: 1
display: flex
flex-flow: row wrap
justify-content: flex-start
align-items: center
border-right: 1px solid
border-color: =props.inactiveForegroundColor
slots:
default:
- component: oh-link // This shows an lightbulb icon which changes depending on the on/off state of the item (It doesn't do any actions!)
iconF7: '=(items[props.item_switch].state == "OFF") ? props.icon_off : props.icon_on'
iconSize: 21px
style:
margin: 0 10px 0 20px
padding: 0px 10px 0px 0px
- component: Label // The name of the item is put here.
text: =props.title
style:
padding: 0px
This piece of code in incomplete to create the actual button I put in a screenshot below. The red marked square is the code you see here.
Sorry I missed this when you first posted. There’s a fairly simple solution. When you assign an action to an oh-list-item then clicking anywhere on that list item will trigger that action. The oh-toggle-item is basically just a list item with a toggle added to its after slot, so you can easily build your own list item that looks just like a toggle item but has the entire click area of the list item
Hi, I am looking something like your’s setup, but not able to setup the widget right. Can’t see any items populated. Any chance if you could share the complete widget code please?
thanks in advance
