It’s been a few months since I’ve made any changes to my system so I’m kind of dusting off the cob webs if you will. I have a z-wave enabled doorbell and I’m trying to make it so I can easily change what sound it plays in a sitemap. I have the sitemap set up fine and can toggle between the different selections. However I’m have a problem with the rule. Here is what I have written up
rule "Door Bell 2"
Item DoorbellNotification received update 1
if (DoorbellNotification.state == 0) {
playSound("db00.mp3")
pushover("Doorbell Rang") }
else if (DoorbellNotification.state == 1){
playSound("db01.mp3")
else if (DoorbellNotification.state == 2){
playSound("db02.mp3")
else if (DoorbellNotification.state == 3){
playSound("db03.mp3")
else if (DoorbellNotification.state == 4){
playSound("db04.mp3")
else if (DoorbellNotification.state == 5){
playSound("db05.mp3")
else if (DoorbellNotification.state == 6){
playSound("db06.mp3")
The result is that no matter what the doorbellnotification is set to, the db01.mp3 plays
rule "Door Bell 2"
switch (DoorbellNotification.state) {
case 0: playSound("db00.mp3")
case 1: playSound("db01.mp3")
case 2: playSound("db02.mp3")
case 3: playSound("db03.mp3")
case 4: playSound("db04.mp3")
case 5: playSound("db05.mp3")
case 6: playSound("db06.mp3")
And as the files are named in that simple way, you even could use:
rule "Door Bell 2"
val String soundfile = "db0" + DoorbellNotification.state.toString + ".mp3"
playSound(soundfile)
That looks promising, definitely cleaner looking. Not sure how that would work with the 2nd thing I’d like to implement. I was waiting until I got the first part done to try it out because you know, one step at a time. I was thinking about trying to make it so the sounds rotate each time the door bell is pressed. Here is my working code, with comments where I’m picturing the command to change the next soundfile, and back to 0 after the 6.
rule "Door Bell 2"
if (DoorbellNotif.state == 0) {
//Change DoorbellNotif.State to 1
else if (DoorbellNotif.state == 1){
//Change DoorbellNotif.State to 2
else if (DoorbellNotif.state == 2){
//Change DoorbellNotif.State to 3
else if (DoorbellNotif.state == 3){
//Change DoorbellNotif.State to 4
else if (DoorbellNotif.state == 4){
//Change DoorbellNotif.State to 5
else if (DoorbellNotif.state == 5){
//Change DoorbellNotif.State to 6
else if (DoorbellNotif.state == 6){
//Change DoorbellNotif.State to 0
Use @Udo_Hartmann rules:
And add a int variable to cycle through the chimes
var int currentChime = 0
rule "Door Bell 2"
val String soundfile = "db0" + String.valueOf(currentChime) + ".mp3"
currentChime = currentChime + 1
if (currentChime > 6) {
currentChime = 0
Note that after a restart on OH, the first chime will always be db00.mp3
Thanks for the feedback. I got an error when I tried loading that code. It says
[100,31]: mismatched input '}' expecting 'end'
Line 100 is the part of the code you provided saying the following
My guess is that I’m getting that error because I don’t have a preceding { in that rule, I could be wrong though, I have a rather elementary understanding of this coding stuff. Trying to learn though. I tried inserting a { in a few different spots trying to troubleshoot it myself but just kept getting different errors instead.
