I wanted to start my Smarthome Environment using a new bought Raspberry Pi 3+. I followed the steps written here: https://www.openhab.org/download/ No problems until Step 5 (installation completed). Using Safari (works only with all Extensions off) on my Mac to reach for http://openhabianpi:8080 a Website will be opened which is simply Malware (Phishing/Trjoan). At the first try of installation Kaspersky blocked the site. On the 2nd try (openhabian new loaded) following all steps anew lead to the same result (this time a new Phishing-Website).
I downloaded Etcher from their website.
My question is: Where is the mistake? Etcher? Openhabian? SD-Card? Or even the raspberry?
Are the sizes right:
Openhabian…img.gz = 254,8MB
Flashed SD-Card: Capacity = 43,1MB, Used = 23,1MB, Available = 251,3 MB
Platform information:
Hardware: iMac with Mac OS 10.14, RaspberryPi 3 B+
Java Runtime Environment: which java platform is used and what version
This sounds more like there is malware installed on your Mac as opposed to the RPi. For one I’ve never heard of such a thing happening on the RPi but I have seen this sort of behavior when a desktop machine gets pwnd with malware. Or it might be your gateway that has been compromised.
You can run some tests to verify some of this though.
From the terminal of a machine, preferably some other machine (or using an app on your phone) run
ping openhabianpi
Does the returned IP address make sense? Is it on your local network? When you ssh to the RPi it tells you the IP address of the machine, does that IP address match what was returned by ping? Can you even ssh to the RPi? If not plug it into a monitor and keyboard and log in that way and see what it says.
If you bring up the OH webpage using the IP address in place of openhabianpi does it work or does it still send you to the phishing site? http://<confirmed ip address of the RPi>:8080.
If the IP address of the RPi doesn’t match what gets returned by ping then for sure you have malware but it isn’t on the RPi. It’s on your Mac or on your gateway. Something has compromised your hosts file or your DNS.
All of the steps above is to identify WHERE the malware is on your network. It won’t fix it. You can’t fix it until you know where the infection resides.
You know for certain you have malware somewhere. Kaspersky can only identify malware that it knows about (i.e. it can’t identify malware it has never seen before) and malware that doesn’t know how to get around. Having an updates system with anti-virus is no guarantee that you are not infected.
No, it’s not only a fake website. It is unknown software running on your network. What you do know is it is malicious. And just because the parts you can see is “just a phishing site” doesn’t mean it isn’t also stealing your account information, transferring all your files, adding your machines to a botnet, or otherwise using your machines to attack someone else.
This is a REALLY BIG DEAL. Don’t be blase about it. You really do need to make the effort to find the source of the problem.
One more test you can make to verify whether it is actually the RPi or not. Unplug it and open http://openhabianpi:8080 in a browser. If you still get the phishing site you know the malware is not on the RPi and running somewhere else on your network.
You also might want to install and run MalwareBytes. It catches a lot of malware that anti-virus does not.
But, unless the unlikely has happened and the malware did come from openHABian, this is going to be a problem for some other forum.
Can you describe the process you followed to set up this SD card. You can’t provide enough detail on this. I want to know every step you took from URLs you went to to download forward.
If it is on the RPi, which seems to be the case, then we need to know how it got there so we can prevent this from happening to others.
Can you post a screenshot of the phishing site you see? That may help identify what the malware is.
I would have assumed that Etcher would have wiped out any hidden partition on the SD card. Maybe not?
Okay. With a new SD-Card I tried the whole Setup again. After long waiting I can provide the following information:
Openhabian is on the RPi installed. Background: Using Terminal.app I got on the RPi by ssh. I have the Login-Screen and already changed the password.
I can not reach http**://openhabianpi:8080 (without **) in Safari/Firefox to get to the OpenHAB-Dashboard. Mistakingly only using http://openhabian gets me to a malicious site (see virustotal.com).
So I have a new problem. But I am one step further.
Another topic shows the solution: Using the ip-Adress-of-pi:8080 shows the dashboard. Seems to be an issue with DNS…
That thread describes a failure in name resolution of the hostname openhabianpi
You reported that you were being redirected to a phishing website when trying to access http://openhabianpi:8080 and/or http://openhabianpi from your PC (and only when the rPi was on).
Are you still getting the Kaspersky warning about the phishing website when you try to use the hostname in the URL?
Looks like somebody registered “openhabianpi.com” and redirects it to phishing/malware sites. In case you just enter “openhabianpi:8080” in the browser and a local host with that name cannot be found, many browsers automatically try openhabianpi.com instead.
So in case anything goes wrong with the installation or the user tries to open the URL too early, before the web server is started, he will be redirected. Although it is not exactly openhabians fault, it sheds a bad light on the project, I would recommend to change the documentation for the installation to avoid this problem.
If you have a recommendation for what to change in the install docs to avoid this problem there is a link at the bottom of the page that will take you straight to that file in GitHub where you can edit it and submit a PR.
i would say, in most cases this is a normal behavior as the browsers take your input as something to be searched and “fixes” the ending of your entry happily.
In this case (if i understand correctly) the openabianpi.com is opened automatically.
In local networks unless the router is not providing any suffix the hostname.local should be used
In other cases the suffix can be configured but usually defaults to what is provided by the vendor (e.g. for fritzbox it is hostname.fritz)
In this thread openhabianpi is mentioned, but I have openhab as hostname for my rpi with the standard OH SD image.
Perhaps it is changed to that in the SD image in the meanwhile.
