Manual binding install not working OH2.2
Hi all please help
running OH on win, i switched to a new system and took all my config with me…
all is working great but one binding i installed by myself and not from Paper UI
the binding is the RMx from Cato
my issue is…
i am not able to see the binding even that i put in addons folder
please help!
where do you expect to see the binding?
does it show up on the OH2 console with:
bundle:list -s
Hi no it is not there is the list
  1. i took the file
  2. put in add-ons folder
  3. power on OH
  4. go to paper ui
Excepted: to see bidining
Actual: nothing in paper or bundle:list -s
are you placing the org.openhab.binding.broadlink-2.2.0-BETA2.jar in the C:\openHAB2\userdata\addons\ folder?
How large is the *.jar file? (it should be: 56.877 bytes)
if it doesn’t show up with bundle:list -s it is not being loaded so something is wrong with the jar
  1. there is no addons under user data…
    c:OH\addons...jar
  2. the jar is fine its in my other system that is working
  3. maybe i need JDK and not JRE?
correct :slight_smile: it should be C:\openHAB2\addons\
no need for JDK
monitor the logs for errors
no erros reg this bundle :frowning:
is there anywhy to clean OH, as this sys was ported from another PC
maybe some links needs to linked again
backup the existing C:\openHAB2\ folder, download a clean zip of 2.3.0 stable and start copying over stuff step by step
oh shit here we go again :slight_smile:
i will try thanks
btw i deployed the org.openhab.binding.broadlink binding on a test windows system running 2.3.0 stable and it was loaded immediately
i was working like a chram for me also …
not sure what happend
i used the DOC mehtod for update
There is currently no automatic update script for Windows. To update manually, download a later version of the openHAB distribution zip file and follow these steps:
Stop the openHAB process if it is currently running.
Backup openHAB as described above.
Delete the following files and folders from your existing install:
userdata\etc\all.policy
userdata\etc\branding.properties…
and this is the only thing not working… maybe i shuld have uninstalled it before i did mig…
can you tell me how to do that?
to uninstall a manually deployed binding, simply delete the *.jar file from the addons folder (and restart OH2, or better: stop,delete,start)
after start, check with bundle:list -s
deleted jar
but still can see it active under list
did you restart OH2?
yes …
i found a way to uninstall bidning from console
bundle:uninstall (number of the bidning)
will this work ?
yes, of course
removing the jar should do it also… (it works on my system)
did both and ported system again to the new computer from the old :frowning:
nothing
@Cato_Sognen please please if you can help here i am using this for my all house
i did it the dirty way…
took the entire folder and its working…
with allot of erros and warinings… hope i will be able to troubleshoot all
