Thanks for the help, but the Problem is not the using of the http-plugin
The Problem is the Player and I don’t know how to manually fill those 4 buttons.
Understood - you could alternatively set up a rule for that:
rule "Player_Control_Handler"
Item SW_PLAYER received command
switch receivedCommand
case PLAY:
sendHttpGetRequest(...)
case PAUSE:
case PREVIOUS:
case NEXT:
Maybe not the elegant way, but if you do not succeed to use the http binding directly from the item, it would be an easy workaround.
