Is there anyway to set RF key manually in Broadlink MQTT Bridge?
I am trying to control a simple RF Sesoo wall switch through Broadlink. It is working just fine if I use some external RF remote for MQTT Bridge to learn the signal and then having the wall switch to learn the same signal.
However, I would like to avoid using external remotes, and I know a good RF generator.
Not sure where do I put the generated key though, is it directly inside the BIN file?
Thanks in advance.
