Manually added items ignored
i’ve got to show the measurements of my weatherstation and installed httpbinding and regex.
I’ve added a *.items file in my openhab2 directory and also a sitemap.
SEN-WS980WiFi.items
// SEN_WS980WiFi
Group    SEN_WS980WiFi "SEN_WS980WiFi" (debug)
Number   SEN_WS980WiFi_temperatur_gefuehlt "Gefühlte Temp. [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=windchillf&convert=f2c:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_temperatur_aussen "Temp. außen [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=tempf&convert=f2c:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_temperatur_innen "Temp. innen [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=indoortempf&convert=f2c:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_taupunkt "Taupunkt [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=dewptf&convert=f2c:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_feuchtigkeit_innen "Feuchtigkeit Innen [%d]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=indoorhumidity:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_feuchtigkeit_aussen "Feuchtigkeit außen [%d]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=humidity:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_wind_geschwindigkeit "Windgeschwindigkeit [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=windspeedmph&convert=m2k:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_wind_boee_geschwindigkeit "Windgeschwindigkeit Böe[%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=windgustmph&convert=m2k:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_wind_richtung "Windrichtung [%d]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=winddir:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_luftdruck_abs "Luftdruck abs. [%.0f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=absbaromin&convert=i2h:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_luftdruck "Luftdruck [%.0f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=baromin&convert=i2h:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_regen_altuell "Regen aktuell [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=rainin&convert=i2m:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_regen_tag "Regen akt. Tag [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=dailyrainin&convert=i2m:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_regen_woche "Regen akt. Woche [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=weeklyrainin&convert=i2m:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_regen_monat "Regen akt. Monat [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=monthlyrainin&convert=i2m:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_regen_jahr "Regen akt. Jahr [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=yearlyrainin&convert=i2m:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_sonne_einstrahlung "Sonne akt. [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=solarradiation:20000:REGEX((.*))]"}
Number   SEN_WS980WiFi_sonne_uv "UV [%.2f]" (SEN_WS980WiFi) {http="<[http://MYSERVER/SEN-WS980WiFi/index.php?read=1&value=UV:20000:REGEX((.*))]"}
SEN-WS980WiFi.sitemap
Frame label="SEN_WS980WiFi" {
	Text item=SEN_WS980WiFi_temperatur_gefuehlt
The items are not shown. Did anyone have an idea why my items are ignored?
Best regards
Chris
When saving the Items file if there is an error it is logged and says the file / changes are ignored. The system knows what the issue is.
Please use code fences when posting configuration here. Spaces matter..
How to use code fences - Tutorials & Examples - openHAB Community
BasicUI etc. will attempt to show you something for a widget, even if the Item given is non-existent.
Maybe your edited sitemap is messed up and ignored.
Like with items file, see what your openhab.log has to say about it.
I’ve viewed the logs and they were full of ERRORs. I think i’ve done to much manipulations to handle this issue. When i began to work with OpenHAB i’ve installed it on ubuntu via the software AND (i don’t know why) via commandline. I’m sure this (and my missunderstanding of the management of rights on linux) was the reason for all my problems. I’ve deleted absolutely all and started completely new. A new installation of ubuntu and a proper installation of OpenHAB and all the bindings. Now everything works fine.
