I have only tested 1.x bindings through /addons folder, but as long as it is “active” (and it shows active on your karaf console) I would just proceed with adding the gateway according to the instructions …
Go to PaperUI -> Configurations -> Things and hit the “+” sign, then the binding name should show up and you can try to autodiscover your Mi Home things.
Make sure you have successfully performed all the required steps before (adding gateway, installing app, …)
Whoa, thank you so much. i was always looking in Add-ons -> Bindings -> for the xiaomi binding which never showed up.
it shows up under things. didnt knew that. solved my problem. thank you so much!
(and it works perfectly )
