Many issues with v2.1
I think I found the easy fix:
Deleting the content of /var/lib/openhab2/cache and /var/lib/openhab2/tmp.
At least openhab is running and accessible again.
But lets go through the error I posted above and try to figure out what the different courses are.
There is no queryable persistence service registered with the id ‘rrd4j’
I guess this is just, because the vaulues for the last few minutes were missing so some values (AVR, MIN, MAX) could not be calculated.
Found multiple local interfaces - ignoring 192.168.1.34
I am not sure yet, but the webservice is accessible via the normal IP address.
So I think this is a problem af a binding maybe. (harmony is not working yet?!)
Validation issues found in configuration model ‘netatmo.things’, using it anyway:
Not sure yet.
Cannot get service reference for transformation service of type MAP
I am not getting this WARN anymore. Deleting the cache might solved this.
Cannot delegate command ‘OFF’ for item ‘Subwoofer_Color’ to handler for channel ‘lifx:colorlight:subwoofer:color’, because no thing with the UID ‘lifx:colorlight:subwoofer’ could be found.
