Many items stop responding after a while since upgrade to OH 4.3.4
  • Platform information:
    • Hardware: Raspberry Pi 4
    • OS: Bookworm
    • Java Runtime Environment: java-17-openjdk-arm64
    • openHAB version: 4.3.4
  • Issue of the topic:
  • I upgraded to OH 4.3.4 to resolve an issue with the Tado smart thermostat. Initially all seemed to work fine but after a certain time most items stopped responding. It seems only MQTT items keep working.
    All items seem to stop reacting at the same time. I can see from data stored at what time the fault occurs, but in the log files there appears to be no error message or other indication something has gone wrong.
    When restarting the OH service or rebooting the system all is working fine again, but after a certain amount of time (varying from about 30 minutes to several hours) the same fault occurs again.
    If I look in Settings>Things in the UI everything appears to be working OK and in the log files I can see commands are sent when pressing a switch on the sitemap or running a rule, but nothing seems to respond, with the exception of MQTT items.
Is there something I am missing?
Same for me.
OH 4.3.4 on openhabian 32bit.
Only MQTT-Items are working without break.
After restart OH-service, all items are working again.
Glad to see I am not alone. I was starting to lose my mind over this. I’ll keep looking to find if there is any specific action that triggers the fault, but so far no joy. Looks like it happens at a random moment.
Unfortunately I have the same issue with 4.3.4 (openHABian on Raspberry Pi 5)
I also saw that stopping the openhab.service with systemctl took very long and according to the status it was killed because of timeouts.
    Process: 1566441 ExecStartPre=/bin/rm -f /var/lock/LCK..ttyAMA0 /var/lock/LCK..ttyACM0 (code=exited, status=0/SUCCESS)
    Process: 1566442 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=killed, signal=KILL)
    Process: 1585037 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
   Main PID: 1566442 (code=killed, signal=KILL)
        CPU: 6min 22.392s
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585207 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585208 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585229 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585231 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585233 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Killing process 1585235 (n/a) with signal SIGKILL.
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Main process exited, code=killed, status=9/KILL
Apr 03 12:04:57 openhabian systemd[1]: openhab.service: Failed with result 'timeout'.
After starting the openhab.service again it could be stopped “normally” with proper “exited” status.
I activated debug logs now.
I had noticed the same, that a service restart took very long. I just checked my logs and noticed the same as in your case, that the service was killed due to time outs during restarts.
It happened again this night and when roaming through the debug logs, I noticed, that the “Decrypting AccessTokenResponse” are missing from the time on when no thing updates are happening anymore.
I suspect that this might be related to the changes done to the OAuth Handling because of the tado binding.
When doing systemctl stop openhab.service, journalctl shows that the OAuthHandler hangs:
Apr 04 06:13:47 openhabian karaf[1594255]: ThreadId: 21796 ThreadName: OH-thingHandler-7 ThreadState: BLOCKED
Apr 04 06:13:47 openhabian karaf[1594255]:   Blocked On: org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl@64ea7726 LockOwnerId: 787 LockOwnerName: OH-thingHandler-1
Apr 04 06:13:47 openhabian karaf[1594255]:   Synchronizers Locked:
Apr 04 06:13:47 openhabian karaf[1594255]:     java.util.concurrent.ThreadPoolExecutor$Worker@16d0b0ac
Apr 04 06:13:47 openhabian karaf[1594255]:   Monitors Locked:
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler@70d79657
Apr 04 06:13:47 openhabian karaf[1594255]:   Stack Trace:
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.getAccessTokenResponse(OAuthClientServiceImpl.java:336)
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.binding.tado.internal.auth.OAuthorizerV2.addAuthorization(OAuthorizerV2.java:49)
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.binding.tado.swagger.codegen.api.client.HomeApi.showHome(HomeApi.java:238)
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.initializeBridgeStatusAndPropertiesIfOffline(TadoHomeHandler.java:167)
Apr 04 06:13:47 openhabian karaf[1594255]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler$$Lambda$1950/0x00000001013c4db0.run(Unknown Source)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
Apr 04 06:13:47 openhabian karaf[1594255]:     java.base@17.0.14/java.lang.Thread.run(Thread.java:840)
@AndrewFG Sorry to ping you here, but did you observe something similar on your side?
In my own JavaScript API calls to the tado API, I noticed that sometimes I don’t get a new access_token when trying to refresh it, because the tado server immediately closed the connection and my refresh attempt just fails.
Could something like this probably lead to a hang like we observe it here?
Following your post I had a look in my system logs. Before a restart of the OH service I see similar messages in journalctl.
Apr 04 08:31:34 openhab karaf[55701]: ThreadId: 667 ThreadName: OH-thingHandler-1 ThreadState: BLOCKED
Apr 04 08:31:34 openhab karaf[55701]:   Blocked On: org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl@7cd90508 LockOwnerId: 670 LockOwnerName: OH-thingHandler-4
Apr 04 08:31:34 openhab karaf[55701]:   Synchronizers Locked:
Apr 04 08:31:34 openhab karaf[55701]:     java.util.concurrent.ThreadPoolExecutor$Worker@7d1f3e39
Apr 04 08:31:34 openhab karaf[55701]:   Monitors Locked: none
Apr 04 08:31:34 openhab karaf[55701]:   Stack Trace:
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.getAccessTokenResponse(OAuthClientServiceImpl.java:336)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.auth.OAuthorizerV2.addAuthorization(OAuthorizerV2.java:49)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.swagger.codegen.api.client.HomeApi.homeState(HomeApi.java:124)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.getHomeState(TadoHomeHandler.java:203)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.updateHomeState(TadoHomeHandler.java:208)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoZoneHandler.updateZoneState(TadoZoneHandler.java:316)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoZoneHandler$1.run(TadoZoneHandler.java:423)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.lang.Thread.run(Thread.java:840)
Apr 04 08:31:34 openhab karaf[55701]: ThreadId: 668 ThreadName: OH-thingHandler-2 ThreadState: BLOCKED
Apr 04 08:31:34 openhab karaf[55701]:     java.util.concurrent.ThreadPoolExecutor$Worker@e3a1305
Apr 04 08:31:34 openhab karaf[55701]: ThreadId: 669 ThreadName: OH-thingHandler-3 ThreadState: BLOCKED
Apr 04 08:31:34 openhab karaf[55701]:     java.util.concurrent.ThreadPoolExecutor$Worker@4e3abda6
Apr 04 08:31:34 openhab karaf[55701]: ThreadId: 670 ThreadName: OH-thingHandler-4 ThreadState: BLOCKED
Apr 04 08:31:34 openhab karaf[55701]:   Blocked On: org.openhab.binding.tado.internal.handler.TadoHomeHandler@2e614b91 LockOwnerId: 671 LockOwnerName: OH-thingHandler-5
Apr 04 08:31:34 openhab karaf[55701]:     java.util.concurrent.ThreadPoolExecutor$Worker@7400d7a1
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl@7cd90508
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler@9dc803e
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.initializeBridgeStatusAndPropertiesIfOffline(TadoHomeHandler.java:131)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.onAccessTokenResponse(TadoHomeHandler.java:245)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.lambda$0(OAuthClientServiceImpl.java:329)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl$$Lambda$2059/0x000000010132e468.accept(Unknown Source)
Apr 04 08:31:34 openhab karaf[55701]:     java.base@17.0.14/java.util.ArrayList.forEach(ArrayList.java:1511)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.refreshToken(OAuthClientServiceImpl.java:329)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.getAccessTokenResponse(OAuthClientServiceImpl.java:352)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.swagger.codegen.api.client.HomeApi.showHome(HomeApi.java:238)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler.initializeBridgeStatusAndPropertiesIfOffline(TadoHomeHandler.java:167)
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler$$Lambda$1913/0x0000000101272770.run(Unknown Source)
Apr 04 08:31:34 openhab karaf[55701]: ThreadId: 671 ThreadName: OH-thingHandler-5 ThreadState: BLOCKED
Apr 04 08:31:34 openhab karaf[55701]:     java.util.concurrent.ThreadPoolExecutor$Worker@20321162
Apr 04 08:31:34 openhab karaf[55701]:     org.openhab.binding.tado.internal.handler.TadoHomeHandler@2e614b91
It looks like cross blocking on a synchronized call. It is probably not because the tado server responds too fast with an error but rather that it doesn’t respond at all. It is complicated to debug because I don’t see the same issues myself.
@AndrewFG, I’m no pro, but also not an absolute beginner. If there is anything I can do/try/test to gather some information that would help to identify the exact issue, let me know and I will have a go.
Just a thought
 I am running PiHole, could that cause an issue?
To get the current status of the tado geofencing I implemented the oauth mechanism via JavaScript rules in parallel to the binding (this was already discussed on Github :slight_smile: )
I.e. the binding uses oauth to communicate with the tado server and additionally I have some rules which use a second oauth access_token to send requests to the API.
The rule which refreshes the “JavaScript access_token” from time to time throws this error when the endpoint https://login.tado.com/oauth2/token is called:
2025-04-04 09:48:00.247 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.io.EOFException: @70d071cd::DecryptedEndPoint@1fdf112{l=/192.168.1.11:54590,r=login.tado.com/13.248.179.194:443,OPEN,fill=-,flush=-,to=300001/0}
If the same happens for the binding, could this somehow block it?
But it’s just a guess, I don’t know the internals of the binding and openHAB core regarding the oauth mechanism
Probably it’s possible to add some timeouts..?
I disabled the tado things for now and guess this will stop the issue
How should we proceed? With an issue on Github?
Exactly. See OAuth prevent concurrent token read / refresh by andrewfg · Pull Request #4686 · openhab/openhab-core · GitHub
@Ironman / @engine I am investigating the possibility that the problem is caused by the tado authentication server blocking without any http timeout; or alternatively if the tcp connection to the server was softly broken, or not even opened at all.
So can you please provide more information about your OH server’s ethernet connection:
  • Is it wifi or wired?
  • Is it on a virtual machine i.e. where the host might softly break tcp connections?
  • Are there any firewalls or spam filters that might block tcp connections, of filter traffic contents?
  • Do you have access to Wireshark? In which case can you see anything odd in your traffic?
Anyway perhaps you could kindly log:set TRACE org.openhab.core.auth and log:set TRACE org.openhab.binding.tado, restart OH, wait for the issue to reappear, and post the respective trace logs?
To answer your questions:
  • wired, Raspberry Pi is connected to router via LAN and router connects to internet
  • no virtual machine, openHAB is running on a Raspberry Pi 5 with openHABian
  • no firewalls or spam filters
  • I did not check wireshark - what would I have to check? :slight_smile:
The logs are active now with TRACE level and I activated the tado things again.
Oh and thanks for checking it so quickly! :slight_smile:
The timing of the HTTP request to the tado authentication server..
  • if/when the socket is opened
  • if/when the OH client sends the HTTP GET/PUT request to https://login.tado.com/oauth2/token
  • if/when the tado server responds (and with what data)
  • if the response ContentLength is longer than the actual response (may cause the client to hang waiting for more data)
  • if/when the socket is closed
Unfortunately I don’t have the experience with wireshark and it seems that some additional setup is necessary which I’d like to avoid on my openHABian.
I checked the logs from tonights fail again and the oauth debug logs end with
2025-04-04 04:00:48.130 [DEBUG] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://login.tado.com/oauth2/token success
There’s no following Decrypting: AccessTokenResponse log which usually follows afterwards.
Ten minutes earlier the refresh was successful:
2025-04-04 03:50:45.793 [DEBUG] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://login.tado.com/oauth2/token success
2025-04-04 03:50:45.795 [DEBUG] [lient.internal.OAuthStoreHandlerImpl] - Decrypting: AccessTokenResponse [accessToken=....
This really looks like the auth core is waiting forever.
There are also no additional TRACE logs from the auth core now that I activated TRACE level.
I guess it won’t help much if I wait now until the issue happens again. As this breaks most of my home automation, I’d rather deactivate it now
 :cold_face: :hot_face:
I’d prefer the timeout workaround tbh :slight_smile:
Yup.
The message ends with the word ‘success’ so we now know that the problem is NOT with the tado server but rather with OH core.
I will add that but it should not be necessary after all..
Hm you’re right; I just tried to understand the code. But it’s too compliated for me :confused:
If the grant type refresh_token is logged, it means that the doRequest() in grantTypeRefreshToken() returns.
Afterwards before grantTypeRefreshToken() itself returns, the shutdownQuietly() is done - could this hang for some reason?
I cannot find out how the Decrypting: AccessTokenResponse log is usually triggered after the grant type refresh_token log.
@engine thanks for looking at the code (I was doing the same..)
Indeed.
No.
That comes from the next normal request being processed for the next zone.
Actually I think the issue is probably the accessTokenRefreshListeners.forEach(l -> l.onAccessTokenResponse(accessTokenResponse)) callback to the tado binding; this causes an immediate online status refresh, which causes another API call, which causes another request to getAccessTokenResponse() ad infinitum.
So there is a new Jar where I break that loop from within the binding – you can download the Jar for test purposes here..
https://github.com/openhab/openhab-addons/pull/18481
Thanks!!
I installed it in the addons folder and got these errors when it loaded:
2025-04-04 18:16:53.331 [ERROR] [.internal.handler.TadoHandlerFactory] - bundle org.openhab.binding.tado:4.3.4.202504041425 (331)[org.openhab.binding.tado.internal.handler.TadoHandlerFactory(456)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77) ~[?:?]
	at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
	at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500) ~[?:?]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:481) ~[?:?]
	at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:326) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1002) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:975) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:920) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220) ~[org.eclipse.osgi-3.18.0.jar:?]
	at java.security.AccessController.doPrivileged(AccessController.java:318) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:534) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:660) [org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2612) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2078) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2061) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:336) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:304) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500) [org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-8.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) [org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.7.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.7.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.7.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.7.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.7.4]
2025-04-04 18:16:53.339 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.3.4 (169)[org.openhab.core.config.discovery.internal.PersistentInbox(135)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=875, service.bundleid=331, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.tado.internal.handler.TadoHandlerFactory, component.id=456}
2025-04-04 18:16:53.339 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.3.4 (169)[org.openhab.core.config.discovery.internal.PersistentInbox(135)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=875, service.bundleid=331, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.tado.internal.handler.TadoHandlerFactory, component.id=456} for reference ThingHandlerFactory
But it is working, I can control the tado thermostats :slight_smile:
I still have TRACE level active. I have four zones in my home and for each periodic update every 30 seconds I see 8 Decrypting: AccessTokenResponse logs and four ApiResponse logs from the TadoZoneHandler. Is this the expected amount of logs?
That is probably only a transient error due to changed thing configuration signature, so we can probably ignore it, but do let me know if you see it again.
:slight_smile:
