Yes, that is good idea, for now I have used JS transformation on the title to show percentage, that is fine and when I go to details I have generated another binding with voltage showings. That is perfect for now.
Thanks for support bud!
Iām also turning aroundā¦
I want to closely monitor my thermal cranes (thermostats) batteries.
They range from 3v (new) to 2.2v (emptyā¦would require an alarm).
So my range goes from 2.2 to 3ā¦and I would like to display it at the levels:
- 2.2v = empty
- 2.4v
- 2.6v
- 2.8v
- 3.0v= full
As a perfect newbie I really donāt understand all the proposals about transform/proxy/othersā¦
Would anyone have a real life example to share ?
Tx!
What actual state do your Items take up? This influences paths available to you.
The battery level is fetched per 0.1 volt.
Perhaps show us an events.log entry.
Or use a 2nd item with range 0-100, standard icons and a rule to trigger upon changes of your original value and to convert it instead of using a transformation. That rule can also issue a warning right away.
Here you go:
2020-11-01 16:41:46.519 [vent.ItemStateChangedEvent] - VanneSalleDeJeu_4_BatteryState changed from NULL to 2.80 V
2020-11-01 17:24:32.551 [vent.ItemStateChangedEvent] - VanneCouloir1erTage_4_BatteryState changed from NULL to 2.30 V
Okay, your Items are quantity types - they have units. You need to know that for your rules and transformations.
The constraint is that dynamic icons only work for 0-100 and only in integer steps, i.e. you get the same icon for 2.1 as 2.9.
So you will have to use a dummy Item with scaled value, as @mstormi suggests.
Optionally, you can add a transformation to un-scale the dummy state for a display text.
Tx.
Could you guide me in setting up that ādummy item with scaled valueā ?
see
Not as evident as you think it is
I keepthinkingā¦
in my sitemap: Text item=ThermostatSalon_2_BatteryState icon=ābatterieā
Where ThermostatSalon_2_BatteryState givesthe value used by the dynamic icon ābatterieā.
Iām an absolute noob when it comes to put my ideas in a āscriptā ā¦ I keep searching
What weāre saying is that Item is no use in your sitemap. Youāve decided you want icons to work a certain way, and that cannot happen using the values that Item takes.
So you need to make another Item that can have a range of values that you can use with icons, and you put that Item on your sitemap instead.
A rule can listen for changes in your original Item, and do some maths on the value and place the scales value into your new dummy Item.
