Map objects not supported anymore?
This has always worked before, so I’m a little confused why it’s not now. I have a rule that fires when all 3 of my KODI devices change to a playing state, it saves the states of the lights using storeStates, and then when it’s paused or ending it sets them back to the way they were. I noticed tonight that the lights were not changing, so I looked, and it’s giving an error every time it tries to save the states.
This is the line that causes the error, and it did work in the past.
BR_PrePlayLevelStates = storeStates(dBR_Lights,dBR_FanLights)
Not sure if something has changed in 1.8.1, or if it’s fixed in 2.x yet, just trying to see if anyone else has had a problem.
The error :
2016-02-22 23:39:37.892 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘BRKodi Changed to Play’
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:112) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:150) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getParamTypes(JavaReflectAccess.java:144) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getMethod(JavaReflectAccess.java:76) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:759) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
at sun.reflect.GeneratedMethodAccessor340.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor339.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(XbaseInterpreter.java:843) ~[na:na]
at sun.reflect.GeneratedMethodAccessor354.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor346.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
