After an update to unstable 1065, and after a reboot I get the following logged.
2017-10-20 08:26:44.458 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:26:44.462 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:26:44.471 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:26:44.475 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.735 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.744 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.751 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.754 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.758 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.762 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.769 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.772 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.777 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.781 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.787 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.790 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.795 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.798 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.809 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.812 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.831 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.834 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.839 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.842 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.892 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.894 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2017-10-20 08:27:05.897 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.899 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn't transform value in label because transformationService of type 'MAP' is unavailable
2017-10-20 08:27:05.902 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2017-10-20 08:27:05.903 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
At Karaf, I do a
feature:list | grep openhab-transformation-map
It shows as uninstalled (was installed before) So I do a
feature:install openhab-transformation-map
…to reinstall it.
I then restart OpenHAB again, now get:
2017-10-20 08:35:46.219 [INFO ] [org.eclipse.smarthome.ui.basic ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.basic
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.9.0.201710180819"; osgi.identity="org.eclipse.smarthome.ui.basic""
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:174) [?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:152) [?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:81) [?:?]
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:57) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:293) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:231) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findEntries(BundleLoader.java:796) [?:?]
at org.eclipse.osgi.container.ModuleWiring.findEntries(ModuleWiring.java:289) [?:?]
at org.eclipse.osgi.storage.ManifestLocalization.findResource(ManifestLocalization.java:200) [?:?]
at org.eclipse.osgi.storage.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:131) [?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getResourceBundle(ManifestLocalization.java:102) [?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getHeaders(ManifestLocalization.java:63) [?:?]
at org.eclipse.osgi.storage.BundleInfo$Generation.getHeaders(BundleInfo.java:124) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.privGetHeaders(EquinoxBundle.java:462) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:457) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:451) [?:?]
at org.apache.felix.metatype.internal.MetaTypeServiceImpl.getMetaTypeInformation(MetaTypeServiceImpl.java:128) [2:org.apache.felix.metatype:1.1.2]
at org.apache.karaf.config.command.completers.MetaCompleter$1.callWith(MetaCompleter.java:71) [45:org.apache.karaf.config.core:4.1.2]
at org.apache.karaf.config.command.completers.MetaCompleter$1.callWith(MetaCompleter.java:63) [45:org.apache.karaf.config.core:4.1.2]
at org.apache.karaf.config.core.impl.MetaServiceCaller.withMetaTypeService(MetaServiceCaller.java:36) [45:org.apache.karaf.config.core:4.1.2]
at org.apache.karaf.config.command.completers.MetaCompleter.updateMeta(MetaCompleter.java:63) [45:org.apache.karaf.config.core:4.1.2]
at org.apache.karaf.config.command.completers.MetaCompleter.init(MetaCompleter.java:49) [45:org.apache.karaf.config.core:4.1.2]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.karaf.shell.impl.action.command.ManagerImpl.instantiate(ManagerImpl.java:103) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.karaf.shell.impl.action.command.ManagerImpl.instantiate(ManagerImpl.java:60) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.karaf.shell.impl.action.command.ManagerImpl.register(ManagerImpl.java:151) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.karaf.shell.impl.action.osgi.CommandExtension.updateState(CommandExtension.java:168) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.karaf.shell.impl.action.osgi.CommandExtension.start(CommandExtension.java:113) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [11:org.apache.karaf.shell.core:4.1.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [11:org.apache.karaf.shell.core:4.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2017-10-20 08:35:46.305 [INFO ] [org.eclipse.smarthome.ui.paper ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.9.0.201710180819"; osgi.identity="org.eclipse.smarthome.ui.paper"; singleton:="true""
2017-10-20 08:35:48.963 [ERROR] [org.openhab.action.mqtt ] - FrameworkEvent ERROR - org.openhab.action.mqtt
org.osgi.framework.BundleException: Could not resolve module: org.openhab.action.mqtt [2470]
Unresolved requirement: Import-Package: org.openhab.io.transport.mqtt
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599) [?:?]
2017-10-20 08:35:52.497 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to en_NZ, Location set to 111111,222222, Time zone set to NZ
2017-10-20 08:35:58.474 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 3f928e5e-ad07-47b1-b2ef-ce1a34a53abe, base URL = http://localhost:8080)
2017-10-20 08:36:08.185 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2017-10-20 08:36:13.243 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2017-10-20 08:36:13.323 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
2017-10-20 08:36:13.366 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
2017-10-20 08:36:13.406 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.persist'
2017-10-20 08:36:13.454 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2017-10-20 08:36:49.018 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2017-10-20 08:36:51.064 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
Followed by…
2017-10-20 08:39:16.522 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-http1, openhab-persistence-mapdb, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-binding-weather1, openhab-misc-hueemulation, openhab-transformation-jsonpath, openhab-binding-mqtt1, openhab-binding-zwave, openhab-binding-harmonyhub, openhab-binding-chromecast, openhab-persistence-mqtt, openhab-persistence-rrd4j, openhab-ui-basic, openhab-transformation-map, openhab-binding-ntp, openhab-action-mail, openhab-binding-astro, openhab-ui-habmin, openhab-binding-expire1, openhab-action-mqtt, openhab-ui-paper, openhab-transformation-scale': Resource has no uri
Going into OH GUI opens, but shows no data. Get the same logs as the ones at the top logged again and doing a feature:list, the bindings show as uninstalled AGAIN.
Help??!!!
