Map transformation: is it possible to transform from switch ON/OFF to contact sensor OPEN/CLOSED
the issue is solved by restart
can you show the thing and channel and item config also what does the event log show when you open and close the window does event log even see item state changing? Click on the tab that says code and post it here please use code fences. It is the button in the top of text box you type posts into that looks like this </> also uses code fences for any log snippets.
Hi sorry I tried to delete the post but failed. There is no issue, the mapping works as expected after restart
