you mean openhab-cli restore ?
OH has to be stopped to import.
Eventually (if it still does not work) stop ZRAM, too, and start again after
this worked, thanks again!
iâve ordered a card reader and a âdouble-sizedâ sd card. i presume the setup in openhabian-config is self-explanatory? (except defining backupdrive
well that I donât know so just try and tell me what you think we would need to change about docs
argh. just wanted to move influxdb to zram:
[15:05:36] root@ohab2:/home/openhabian# service zram-config stop
[15:07:38] root@ohab2:/home/openhabian# nano /etc/ztab
[15:12:16] root@ohab2:/home/openhabian# zramctl
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram2 lzo-rle 500M 17.5M 402.2K 844K 4
/dev/zram1 lzo-rle 500M 30.1M 1.6M 2M 4
shouldnât zramctl give an âemptyâ output?
[15:12:20] root@ohab2:/home/openhabian# systemctl status zram-config.service
â zram-config.service - zram-config
Loaded: loaded (/etc/systemd/system/zram-config.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Thu 2020-09-10 15:07:38 CEST; 5min ago
Process: 331 ExecStartPre=/usr/local/sbin/zramsync recover /storage/zram (code=exited, status=0/SUCCESS)
Process: 483 ExecStart=/usr/local/sbin/zram-config start (code=exited, status=0/SUCCESS)
Main PID: 483 (code=exited, status=0/SUCCESS)
Sep 10 14:22:42 ohab2 zram-config[483]: + mkdir -p /opt/zram/zram2/upper /opt/zram/zram2/workdir /var/lib/openhab2/persi
Sep 10 14:22:42 ohab2 zram-config[483]: + mount --verbose --types overlay -o redirect_dir=on,lowerdir=/opt/zram/persiste
Sep 10 14:22:42 ohab2 zram-config[483]: + chown 110:115 /opt/zram/zram2/upper /opt/zram/zram2/workdir /var/lib/openhab2/
Sep 10 14:22:42 ohab2 zram-config[483]: + chmod 755 /opt/zram/zram2/upper /opt/zram/zram2/workdir /var/lib/openhab2/pers
Sep 10 14:22:42 ohab2 zram-config[483]: + echo 'dir /zram2 /var/lib/openhab2/persistence
Sep 10 14:22:42 ohab2 zram-config[483]: + read -r line
Sep 10 14:22:42 ohab2 zram-config[483]: + [[ false == \t\r\u\e ]]
Sep 10 14:22:42 ohab2 systemd[1]: Started zram-config.
Sep 10 15:07:38 ohab2 systemd[1]: zram-config.service: Succeeded.
Sep 10 15:07:38 ohab2 systemd[1]: Stopped zram-config.
Only if it manages to unmount everything to access the zramâed dirs which it usually doesnât (just to many dependencies).
Adding dirs to ztab should work nonetheless.
seems to work, yes. after reboot i had the 4 entries (as configured):
[15:27:43] openhabian@ohab2:~$ zramctl
/dev/zram3 lzo-rle 500M 48.6M 51.6K 320K 4 /opt/zram/zram3
/dev/zram2 lzo-rle 500M 17.5M 285.4K 728K 4 /opt/zram/zram2
/dev/zram1 lzo-rle 500M 30.3M 1.5M 2M 4 /opt/zram/zram1
/dev/zram0 lzo-rle 600M 4K 87B 12K 4 [SWAP]
before reboot (but with started zram-config) i had these 4 entries PLUS the 2 entries from above.
