Hi, is it possible not to see the on/off state of a switch I mapped?
Yep. In your label, you have to specify that there’s no output.
label="PC Dell []"
You can do this in the item or in the sitemap.
Perfect…thank you! I’m going to ask another question. If I just want to see the current state of the buttons I’ve mapped? Do I have to use the visibility function?
Can you see one is “lit” and the other isn’t? The UI widget does that for you.
Sitemap visibility is about showing/hiding whole lines.
That is clear, but I was wondering if there was a way to visualise only the current state…
As you supressed the unwanted state display with an empty state presentation [], you would use one with with content to produce a display.
[%s]
is pretty bulletproof.
You could create a String item and use rules to change the text and display that in a sitemap.
Text item=Tv_state icon="screen" label="[%s]"
