I upgraded to the latest nightly … and have huge CPU usage and hence performance issues since then.
From the log I cannot tell the source… any tips?
log just shows the following which is probably only a result of the massive performance issues:
18:59:45.457 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
18:59:50.467 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
18:59:52.347 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
19:00:13.888 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
19:00:16.873 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
19:00:16.878 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:18.900 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
19:00:18.901 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:21.880 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.io.myopenhab.internal.MyOpenHABService@184512e' takes more than 5000ms.
19:00:23.903 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@d75812' takes more than 5000ms.
19:00:25.891 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:27.140 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@44b760' takes more than 5000ms.
19:00:30.108 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:30.893 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@15649' takes more than 5000ms.
19:00:31.098 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:35.109 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@60f394' takes more than 5000ms.
19:00:35.110 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:36.099 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.io.myopenhab.internal.MyOpenHABService@184512e' takes more than 5000ms.
19:00:38.656 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:40.111 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@d75812' takes more than 5000ms.
19:00:40.112 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:43.657 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@5a9aa6' takes more than 5000ms.
19:00:43.658 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:45.113 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@15649' takes more than 5000ms.
19:00:45.115 [WARN ] [rthome.core.common.ThreadPoolManager] - Thread pool 'safeCall' rejected execution of class java.util.concurrent.FutureTask
19:00:48.659 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1524aec' takes more than 5000ms.
19:00:50.116 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.io.myopenhab.internal.MyOpenHABService@184512e' takes more than 5000ms.
