Hey all devs,
I been playing lately with development of side extension and found an unexpected thing - openhab bill of material poms do not provide a dependencyManagement
section. This means that by importing any openhab BOM you always get all dependencies declared there, even if you need only.
The main reason why I bring it here is because standard use (at least which I have seen in other projects) of BOMs is to manage dependencies and their versions and not only “import” dependencies. People who use then such a BOM can refer dependencies without explicit versions as they are inherited from base project.
For example:
org.openhab.core.bom.compile:
<dependencies>
<dependency>
<groupId>org.osgi</groupId>
<artifactId>osgi.core</artifactId>
<version>6.0.0</version>
</dependency>
</dependencies>
This means that such dependency is propagated to every project which imports org.openhab.core.bom.compile
. There are much more dependencies in same pom which gets into every binding/transport/io module.
In other project BOMs dependencies such this are listed in different way:
<dependencyManagement>
<dependencies>
<dependency>
</dependency>
</dependencies>
</dependencyManagement>
This means that project after importing a BOM still needs to declare explicit dependency on org.osgi:org.osgi
and other things as needed.
I am aware that current use of BOMs drastically simplifies binding development as their developers don’t have to worry about all modules, however shouldn’t we make it a bit smarter and at least let proper use of Maven dependencies? Could we (as OH project) provide a different variant of BOM, one which promotes fine grained control over classpath?
Cheers,
Łukasz
