Hi there,
I would like to be able to change the setting of Boost in the rules, however I don’t find the way to do.
In the original web interface of MAX! Cube you can set what boost does, like boost time and valve opening. this is by default set to 10 min and 80% valve opening. I would like to be able to change it in the rule or via UI in sitemap.
Is that possible?
does it need to implement a new channel? how to do it?
is there any other advice on how to set a specific valve opening on a thermostat?
This is not possible with the current binding.
It would require to develop the additional channel & commands to send this parameter to the thermostat
note, I believe there is no regular command to specifically set the valve% during regular operation, we send the temperature to the thermostat not the valve%. The workaround might be to always use the boost mode if that mode allows you to set the valve% but you are in untested waters with such a way.
Thanks Marcel!
Indeed the boost allow you to set the valve opening. I do it now by setting the web interface of the MAX!Cube.
This is useful for floor heating or other similar applications hwne you wan to actuate directly the valve.
