I’m using MX!Cube with their native web interface, but planned to migrate to OH2. Unfortunately, binding does not seem to work.
My set up is wall thermostat and valve, connected to each other. None of the readings were ever updated in OH2, moreover, when I try to set setpoint, it does not get updated with strange error:
2016-10-27 00:05:25.848 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Run MAX! Cube discovery
2016-10-27 00:05:26.049 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - MAX! Cube found on network
2016-10-27 00:05:26.050 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Found at : 192.168.0.125
2016-10-27 00:05:26.051 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Serial : KEQ0533879
2016-10-27 00:05:26.051 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - RF Address: 095533
2016-10-27 00:05:26.051 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Firmware : 01.13
2016-10-27 00:05:31.057 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Done receiving discovery messages.
2016-10-27 00:05:35.211 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection... to 192.168.0.125 port 62910
2016-10-27 00:06:10.220 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection... to 192.168.0.125 port 62910
2016-10-27 00:06:45.227 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection... to 192.168.0.125 port 62910
2016-10-27 00:06:51.267 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2016-10-27 00:06:51.381 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2016-10-27 00:06:56.910 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 0 (NEQ0657759-set_temp:15).
2016-10-27 00:06:57.475 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 0 (NEQ0657759-set_temp) from queue. Superceeded by 1
2016-10-27 00:06:57.476 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 1 (NEQ0657759-set_temp:15.5).
2016-10-27 00:06:57.603 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 1 (NEQ0657759-set_temp) from queue. Superceeded by 2
2016-10-27 00:06:57.603 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 2 (NEQ0657759-set_temp:16).
2016-10-27 00:06:57.742 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 2 (NEQ0657759-set_temp) from queue. Superceeded by 3
2016-10-27 00:06:57.743 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 3 (NEQ0657759-set_temp:16.5).
2016-10-27 00:06:57.883 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 3 (NEQ0657759-set_temp) from queue. Superceeded by 4
2016-10-27 00:06:57.883 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 4 (NEQ0657759-set_temp:17).
2016-10-27 00:06:58.018 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 4 (NEQ0657759-set_temp) from queue. Superceeded by 5
2016-10-27 00:06:58.019 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 5 (NEQ0657759-set_temp:17.5).
2016-10-27 00:06:58.158 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 5 (NEQ0657759-set_temp) from queue. Superceeded by 6
2016-10-27 00:06:58.158 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 6 (NEQ0657759-set_temp:18).
2016-10-27 00:06:58.298 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Removed Command id 6 (NEQ0657759-set_temp) from queue. Superceeded by 7
2016-10-27 00:06:58.300 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Command queued id 7 (NEQ0657759-set_temp:18.5).
2016-10-27 00:06:58.389 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Cannot send command to device with serial number NEQ0657759, device not listed.
I tried setting with wall thermostat and TRV itself, no luck. Any hints?
