Like this, but is it not working can you see if I have errors in the code,
2021-01-27 12:52:17.609 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘tempudv-1’ failed: The name ‘df’ cannot be resolved to an item or type; line 21, column 71, length 2 in tempudv
//import java.text.SimpleDateFormat
//import java.util.Date
rule "Temperatur Min-og Max values Carportnord"
Item Temperatur_Udebygninger_Carportnord received update
var Number Min
var Number Max
var String tmp
//var SimpleDateFormat df = new SimpleDateFormat( "HH:MM" )
val hmformat = java.time.format.DateTimeFormatter.ofPattern("HH:mm")
if (Temperatur_Udebygninger_Carportnord.state instanceof DecimalType) {
logInfo("test", "TempUC " + Temperatur_Udebygninger_Carportnord.state.toString)
Min = (Temperatur_Udebygninger_Carportnord.minimumSince(now.with(LocalTime.MIN), "rrd4j").state as DecimalType)
logInfo("test", "Min " + Min.toString)
tmp = (Math::round(Min.floatValue*10.0)/10.0) + " °C (" + df.format(Temperatur_Udebygninger_Carportnord.minimumSince(now.with(LocalTime.MIN, "rrd4j").timestamp.format(hmformat) + ")"))
postUpdate(Temperatur_Udebygninger_Carportnord_Min, tmp)
Max = Temperatur_Udebygninger_Carportnord.maximumSince(now.with(LocalTime.MAX, "rrd4j").state as DecimalType )
tmp = (Math::round(Max.floatValue/10.0) + " °C (" + df.format(Max.timestamp.format(hmformat) + ")"))
postUpdate(Temperatur_Udebygninger_Carportnord_Max, tmp)
sorry a lot, but I’m not a programmer just a happy fitter who is not so good at English so I do not write so much about what I think could be the mistake and where I get stuck, I should probably make myself more understandable about this
Here I have // the lines where DF is included
and here is what the log now says
2021-01-27 14:26:22.691 [INFO ] [org.openhab.core.model.script.test ] - Min state -2.43
2021-01-27 14:26:22.692 [INFO ] [org.openhab.core.model.script.test ] - Min stamp 02:00
2021-01-27 14:26:22.692 [INFO ] [org.openhab.core.model.script.test ] - TempUC 1.31
2021-01-27 14:26:22.694 [INFO ] [org.openhab.core.model.script.test ] - Min -2.43
2021-01-27 14:26:22.696 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘tempudv-1’ failed: An error occurred during the script execution: Could not invoke method: java.time.ZonedDateTime.with(java.time.temporal.TemporalField,long) on instance: 2021-01-27T14:26:22.696025+01:00[Europe/Copenhagen] in tempudv
var Number Min
//var Number Max
var String tmp
var record = (Temperatur_Udebygninger_Carportnord.minimumSince(now.with(LocalTime.MIN), "rrd4j"))
logInfo("test", "Min state " + record.state.toString)
logInfo("test", "Min stamp " + record.timestamp.format(hmformat))
//tmp = (Math::round(Min.floatValue*10.0)/10.0) + " °C (" + df.format(Temperatur_Udebygninger_Carportnord.minimumSince(now.with(LocalTime.MIN, "rrd4j").timestamp.format(hmformat) + ")"))
//tmp = (Math::round(Max.floatValue/10.0) + " °C (" + df.format(Max.timestamp.format(hmformat) + ")"))
hurray, so we’ve guessed how to get the persistence timestamp into the hh:mm form you want.
Let’s have a tidy up now.
No imports at all.
var Min = Temperatur_Udebygninger_Carportnord.minimumSince(now.with(LocalTime.MIN), "rrd4j")
// changed so that Min is the whole database record
var tmp = (Min.state as DecimalType).format("%.1f") + " °C (" + Min.timestamp.format(hmformat) + ")"
// changed to make it simpler and more efficient,less database accessing
var Max = Temperatur_Udebygninger_Carportnord.maximumSince(now.with(LocalTime.MAX, "rrd4j")
tmp = (Max.state as DecimalType).format("%.1f") + " °C (" + Max.timestamp.format(hmformat) + ")"
2021-01-27 20:17:43.760 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘tempudv-1’ failed: Invalid start/end time in fetch request: 1611788399 > 1611775063 in tempudv
rule code
var Max = Temperatur_Udebygninger_Carportnord.maximumSince(now.with(LocalTime.MAX), "rrd4j")
Typo on my part,you could have worked this out by comparing working Min part with non-working Max part, and using the "Invalid start/end time" clue to look closely at the timey code.
Not
(now.with(LocalTime.MAX, “rrd4j”)
but
(now.with(LocalTime.MAX), “rrd4j”)
I still have this error whit and whitout the var ind front of tmp max
2021-01-27 20:57:46.872 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘tempudv-1’ failed: Invalid start/end time in fetch request: 1611788399 > 1611777466 in tempudv
when i removed the var in front of tmp max i got this allso
2021-01-27 21:02:38.376 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘tempudv.rules’, using it anyway:
The value of the local variable Min is not used
var Max = Temperatur_Udebygninger_Carportnord.maximumSince(now.with(LocalTime.MIN), "rrd4j")
rule "Минимальные и максимальные значения температуры"
Item Meteo_Temperature1 received update
if (Meteo_Temperature1.state instanceof DecimalType) {
logInfo("test", "TempUC " + Meteo_Temperature1.state.toString)
var Min = Meteo_Temperature1.minimumSince(now.with(LocalTime.MIN, "rrd4j").state as DecimalType)
postUpdate(Meteo_Temperature1_Min, tmp)
var Max = Meteo_Temperature1.maximumSince(now.with(LocalTime.MAX, "rrd4j").state as DecimalType)
postUpdate(Meteo_Temperature1_Max, tmp)
Hello everyone.The rule does not work. Min.temp. shows Err, and Max. just a dash and a degree Celsius. What could be the problem? OpenHAB 3.2 is installed.
We have no way of finding out. This is up to you. What is in your openhab.log ? You’ve got a logInfo(), for example. What does that say? What about those postUpdate(), do you see any changes in your events.log ?
Do you think you might be having exactly the same issue that you’ve already read about in this thread, now.with(LocalTime.MAX) is in the future and persistence service cannot see into the future?
You need to take care with brackets as well, xxx.minimumSince(now.with(LocalTime.MIN, "rrd4j")
makes no sense, .now.with() doesn’t want a second parameter.
Try xxx.minimumSince(now.with(LocalTime.MIN), "rrd4j")
so that “rrd4j” is a parameter for minimumSince() instead
2021-09-05 16:11:00.562 [INFO ] [org.openhab.core.model.script.test ] - TempUC 16.9
2021-09-05 16:11:00.666 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘Meteo-1’ failed: ‘state’ is not a member of ‘org.openhab.core.library.types.DecimalType’; line 15, column 24, length 9 in Meteo
Okay, I’m out. I appreciate there is a language barrier, but you have to give more info.
The point about brackets is that is important where you put them. They were in the wrong place. The next person to help you would like to know where they are now.
var Min = Meteo_Temperature1.minimumSince(now.with(LocalTime.MIN),"rrd4j").state as DecimalType
var Max = Meteo_Temperature1.maximumSince(now.with(LocalTime.MAX),"rrd4j").state as DecimalType
