Maxcube Binding / Configure
Hello there,
I have a MAX! Maxcube ELV system.
The temperatures do not appear to me. The ELV software is closed.
openhab V 1.7.1 MaxCube V 1.4.1
My Config:
openhub.cfg
################################ MAX! Cube Binding ############## #######################
# MAX! Cube LAN Gateway IP Address (Optional, can be auto-discovered)
Maxcube: ip = 192.168.188.222
*.items
Group All
Group gEG (All)
/* Gang */
Number Heating_Max “Thermostat Gang [%.1f °C]” (gEG) {maxcube=“JEQ0386989”}
What am I doing wrong?
The log: C: \ OpenHub \ logs \ Maxcube is empty.
Thank you
First thing to do is avoiding the spaces and using non capital letters, instead of
type
maxcube:ip=192.168.188.222
Did you really install openhab in folder
C: \ OpenHub \ ???
Wouldn’t do that, I assume it could cause problems, but I am not sure, use instead
C:\OpenHab\ or even better use non capital letters C:\openhab\
and the config file is called openhab.cfg, not openhub.cfg, but maybe that’s a typo …
Good luck.
Hello there,
in the IP address I have no distances, I think, by copy and paste something went wrong.
attached one screenshots
I thank you, because everything should be right …
thank you
[quote=“Christoph_Purin, post:3, topic:3223, full:true”]
… because everything should be right …[/quote]
That means it is working now? Great.
It’s cold at your place, only 1 degrees … :grinning:
Unfortunately, no does not work
I think that the configuration is correct.
The “Maxcube” Log in “C:\openhub\logs\maxcube” is still empty, is this normal?
Why are you looking in a folder named maxcube for log details? It should be a file named maxcube.log.
And the log goes only in a file maxcube.log if you changed logback.xml to do so.
If you didn’t change logback.xml the log of the maxcube binding goes to openhab.log.
I have add:
go to Loggin
and
To log even more information, set the level of org.openhab.binding.maxcube from DEBUG to TRACE or ALL
to ALL
<appender name="MAXCUBE" class="ch.qos.logback.core.rolling.RollingFileAppender">
<file>${openhab.logdir:-logs}/maxcube.log</file>
<rollingPolicy class="ch.qos.logback.core.rolling.TimeBasedRollingPolicy">
    <!-- weekly rollover and archiving -->
    <fileNamePattern>${openhab.logdir:-logs}/maxcube-%d{yyyy-ww}.log.zip</fileNamePattern>
    <!-- maximum number of archive files to keep -->
    <maxHistory>30</maxHistory>
</rollingPolicy>
<encoder>
    <pattern>%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5level] [%-30.30logger{36}] - %msg%n</pattern>
</encoder>
logback.xml:
<configuration scan="true">
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
	<encoder>
	</encoder>
</appender>
<appender name="FILE" class="ch.qos.logback.core.rolling.RollingFileAppender">
	<file>${openhab.logdir:-logs}/openhab.log</file>
		<fileNamePattern>${openhab.logdir:-logs}/openhab-%d{yyyy-ww}.log.zip</fileNamePattern>
	</rollingPolicy>
	<encoder>
	</encoder>
</appender>
<appender name="EVENTFILE" class="ch.qos.logback.core.rolling.RollingFileAppender">
	<file>${openhab.logdir:-logs}/events.log</file>
		<fileNamePattern>${openhab.logdir:-logs}/events-%d{yyyy-ww}.log.zip</fileNamePattern>
	</rollingPolicy>
	<encoder>
		<pattern>%d{yyyy-MM-dd HH:mm:ss} - %msg%n</pattern>
	</encoder>
</appender>
<logger name="runtime.busevents" level="INFO" additivity="false">
	<appender-ref ref="EVENTFILE" />
	<appender-ref ref="STDOUT" />
</logger>
<logger name="org.openhab" level="INFO"/>
<!-- this class gives an irrelevant warning at startup -->
<logger name="org.atmosphere.cpr.AtmosphereFramework" level="ERROR" />
<!-- temporary workaround for https://github.com/openhab/jmdns/issues/12 -->
<logger name="javax.jmdns" level="OFF"/>
<!-- temporary workaround for https://bugs.eclipse.org/bugs/show_bug.cgi?id=402750 -->
<logger name="OSGi" level="OFF" />
<!-- temporary workaround to circumvent error messages with any obvious effect -->
<logger name="org.atmosphere.cpr.AtmosphereFramework" level="OFF" />
<logger name="org.atmosphere.cpr.DefaultAnnotationProcessor" level="OFF" />
<root level="WARN">
	<appender-ref ref="FILE" />
</root>
</rollingPolicy>
<encoder>
</encoder>
According to your screenshot you get humidity and temperature on your openhab bus. Are those from your maxcube or do you have any other weather service enabled?
If this comes from your maxcube, your config is allright, then you have to look for your items and/or sitemap definition for the problem.
Because I don’t use maxcube I cannot help you with your item definition, but it looks okay according to the binding page.
If this is your complete logback.xml one part is missing:
<logger name="org.openhab.binding.maxcube" level="ALL">
    <appender-ref ref="MAXCUBE" />
</logger>
Just add the addition on this page to your logback.xml, change DEBUG to ALL and you should be good to go.
stoffl.sitemap
    sitemap stoffl label="Stoffl @ Home"
    	Frame {
    		Group item=gEG label="Erdgeschoß" icon="firstfloor"
stoffl.items
Group All
Group gEG		(All)
/* Gang */
Number Heating_Max "Thermostat Gang [%.1f °C]" (gEG) {maxcube="JEQ0386989"}
I do not know what I’m doing wrong … I think openhab not komuniziert the Maxcube. I can ping the Maxcube - so do not have a Duty - Cycle achieved.
When I close openhab and Max Softare open, then I see the values - the sensors to talk to the Maxcube
New: logback
	<encoder>
	</encoder>
</appender>
	</rollingPolicy>
	<encoder>
	</encoder>
</appender>
	</rollingPolicy>
	<encoder>
	</encoder>
</appender>
</rollingPolicy>
<encoder>
</encoder>
</logger>
<!-- looger MAX Cube -->
</logger>
<root level="WARN">
</root>
That logback.xml looks some sort of strange to me, do you have two files or did you just apply a wrong format for “preformatting text” in this forum software?
Take this and replace it with your logfile.xml, it is the default logback with added maxcube logging in a separate file under /logs/maxcube.log
        <encoder>
        </encoder>
    </appender>
        </rollingPolicy>
        <encoder>
        </encoder>
    </appender>
        </rollingPolicy>
        <encoder>
        </encoder>
    </appender>
        <!-- put maxcube log in separate file maxcube.log -->
    </rollingPolicy>
    <encoder>
    </encoder>
</appender>
</logger>
    </logger>
    <root level="WARN">
    </root>
</configuration>
But anyway, according to your screenshot of the openhab startup process you have your temperature on your openhab bus and I cannot find any problems in your sitemap or items file.
So I don’t know where the problem is, sorry.
Have solved the problem, you must also install the correct Addon among addons, then does it all =)
A few questions remain unanswered:
How can I add a eco switch?
How can I send the thermostat a value? - I found this a bit, unfortunately very little with it
Sitemap page:
Setpoint item=Heating_Max_michelle_soll label="Heizung Michélle" minValue=6 maxValue=25 step=1.0
Items page
Number Heating_Max_michelle_soll “Heizung Soll [%.1f °C]” (OG_Kinderzimmer2) {maxcube=“JEQ0390544”}
greeting
For the ecoswitch there is little to control. I think you can add it, but It does not send it’s status information with any meaningful information (outside battery level). Therefore even in the original application of the vendor you can’t see the ecoswitch status
In the logs of the maxcube binding there is the actual temperature… how can I display this in openhab ?
“Thermostat Temperature [%.1f °C]” (MyGroup) { maxcube=“JEQ0336148:type=actual” }
See also
For more details (esp that it does not always provide data)
