I get this exception when trying to use MaryTTS on Openhab 2 (Say test in Promt):
javax.sound.sampled.LineUnavailableException: line with format PCM_SIGNED 16000.0 Hz, 16 bit, mono, 2 bytes/frame, little-endian not supported. at com.sun.media.sound.DirectAudioDevice$DirectDL.implOpen(DirectAudioDevice.java:513) at com.sun.media.sound.AbstractDataLine.open(AbstractDataLine.java:121) at com.sun.media.sound.AbstractDataLine.open(AbstractDataLine.java:153) at marytts.util.data.audio.AudioPlayer.run(AudioPlayer.java:206)
Openhab2 on Odroid U3, MarryTTS installed via Paper UI…
Is there something I am missing or is this a bug?
Thanks!
MM
