I’m new to OH and start with the OH 2.2 on RASPBERRY PI 3B. (Openhabian 1.4)
I want to handle 64 GPIO pins as a Input and another 64 GPIO pins as output to control relays. So, all IO pin count is 128. And as I understand, MCP23017 is the only way to fulfill my need.
But, Right after I copy manually 1.9 jar file of MCP23017 binding to the OH Addons folder, OH whole service interrupted and I can’t access even to paper ui.
Honestly, I would use an external Python script to interact with your GPIO pins and set up integration between them using MQTT. In fact, I have done this, though I did it primarily because my GPIOs were not on the same host as my OH server.
Thank you for the reply. I tried to install older version of OH. But while installing it is upgrading itself to latest version. May be I should pick out more about it.
