I am have followed the instructions giving on the openhab website to install and configure mcp23017.
I have already installed the wiringpi library and tested by command lines [ This part is working.]. I have also install pi4j but still cannot get it to work into openhab. Below is the trace error:
Error
2019-05-11 21:38:52.961 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.mcp23017.handler.Mcp23017Handler@46d970’: null
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:545) ~[?:?]
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalOutputPin(GpioControllerImpl.java:717) ~[?:?
at org.openhab.binding.mcp23017.handler.Mcp23017PinStateHolder.initializeOutputPin(Mcp23017PinStateHolder.java:71) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017PinStateHolder.getOutputPin(Mcp23017PinStateHolder.java:59) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleOutputCommand(Mcp23017Handler.java:108) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleCommand(Mcp23017Handler.java:80) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy138.handleCommand(Unknown Source) [239:org.openhab.binding.mcp23017:2.4.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
Probably a configuration error. Hard to say since you didn’t post your configuration.
You should pull a debug log to get a better idea of what’s causing the problem.
I can’t help because you haven’t provided any information I can use to help you.
If you can provide a debug log that contains the scenario, that would be a good start.
I removed all configured things, items and started again from scratch
adding thing
Thing mcp23017:mcp23017:shutter_1_8 "MCP23017 shutter 1_8" [address=24,bus=1] {
Type output_pin : output#A0 [default_state="LOW", active_low="n"]
Type output_pin : output#A1 [default_state="HIGH", active_low="n"]
log
2020-03-02 21:41:34.694 [hingStatusInfoChangedEvent] - 'mcp23017:mcp23017:shutter_1_8' changed from UNINITIALIZED to INITIALIZING
2020-03-02 21:41:34.713 [WARN ] [.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
2020-03-02 21:41:34.726 [hingStatusInfoChangedEvent] - 'mcp23017:mcp23017:shutter_1_8' changed from INITIALIZING to ONLINE
2020-03-02 21:41:34.726 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalOutputPin(GpioControllerImpl.java:717) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleOutputCommand(Mcp23017Handler.java:110) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleCommand(Mcp23017Handler.java:79) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:191) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.channelLinked(Mcp23017Handler.java:221) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:267) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-03-02 21:46:01.786 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'DOM.items'
2020-03-02 21:46:01.816 [.ItemChannelLinkAddedEvent] - Link 'shutter_1_up-mcp23017:mcp23017:shutter_1_8:output#A0' has been added.
2020-03-02 21:46:01.818 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-03-02 21:46:01.827 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-03-02 21:46:01.821 [.ItemChannelLinkAddedEvent] - Link 'shutter_1_down-mcp23017:mcp23017:shutter_1_8:output#A1' has been added.
Sorry I can not help you with this problem. But I can tell you that openhab 2.5 and MCP binding 2.4 is working fine on my system. Binding 2.5 is not working. Only for your information
I am just wondering about the output parameter “active low”. I never used it. And the documentation mentioned “default_state” as additional parameter only. Only the example shows the “active low”. Maybe you should try it without this parameter.
