i had an item “KNX_Stati_Status_Heizung” which states i recorded with a persistence. This had Percentage values in there and all was fine.
Yesterday i changed type of controller and it is now only generating ON/OFF as a switch. So i tried, had problems and so i deleted the item and recreated it with same name as a switch item.
The item gets the states correctly from knx. The problem i have is that it is not persisting the values any more.
For persistence im using a group named gpersist and this is attached to the item.
If im greping the Log then im getting this:
grep KNX_Stati_Status_Heizung /data/openhab/openhab_userdata/logs/openhab.log
com.influxdb.exceptions.UnprocessableEntityException: failure writing points to database: partial write: field type conflict: input field "value" on measurement "KNX_Stati_Status_Heizung" is type integer, already exists as type float dropped=1
Is there a possibility to correct this for not losing the history or is the only solution to use a new name for avoiding this?
