Medion robot md 18318 binding
Can anyone develop a Binding for the Medion robot md 18318 ?
Is there an open API available ? If not, the chance to get a Binding is tending to zero.
API not available.
Maybe you see the commands if you are sniffing the network
…or the easy way: waiting Medion publish the API
In that case, don’t expect someone to develop a Binding for you.
True. We are all volunteers.
The best way to get a binding is to try something yourself, even if it is not polished. That can spur interest & help from others.
ok then I try it myself and see that I lay a foundation stone as @Bruce_Osborne says. Do you have any other idea than to sniff the network?
I googled a bit, but could not find any hint that it is supported by other home automation software, so paket sniffing will be the best approach.
