Melcloud doesn't connect after upgrade from OH3 to OH4
After successful setup of my AC with the Meldcloud-binding, I am facing an error after upgrading the system to openHAB 4.
I already tried to clear the cache, reboot, but nothing changed.
This is the error thrown to the log:
java.lang.NullPointerException: Cannot invoke "org.openhab.binding.melcloud.internal.api.MelCloudConnection.isConnected()" because "this.connection" is null
	at org.openhab.binding.melcloud.internal.handler.MelCloudAccountHandler.isConnected(MelCloudAccountHandler.java:127) ~[?:?]
	at org.openhab.binding.melcloud.internal.handler.MelCloudAccountHandler.connectIfNotConnected(MelCloudAccountHandler.java:121) ~[?:?]
	at org.openhab.binding.melcloud.internal.handler.MelCloudAccountHandler.getDeviceList(MelCloudAccountHandler.java:96) ~[?:?]
	at org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService.discoverDevices(MelCloudDiscoveryService.java:89) ~[?:?]
	at org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService.startBackgroundDiscovery(MelCloudDiscoveryService.java:65) ~[?:?]
	at org.openhab.core.config.discovery.AbstractThingHandlerDiscoveryService.initialize(AbstractThingHandlerDiscoveryService.java:119) ~[?:?]
	at org.openhab.core.thing.binding.BaseThingHandlerFactory$RegisteredThingHandlerService.initializeService(BaseThingHandlerFactory.java:395) ~[?:?]
	at org.openhab.core.thing.binding.BaseThingHandlerFactory.registerThingHandlerService(BaseThingHandlerFactory.java:208) ~[?:?]
	at org.openhab.core.thing.binding.BaseThingHandlerFactory.registerServices(BaseThingHandlerFactory.java:160) ~[?:?]
	at org.openhab.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:147) ~[?:?]
	at org.openhab.core.thing.internal.ThingManagerImpl.doRegisterHandler(ThingManagerImpl.java:531) ~[?:?]
	at org.openhab.core.thing.internal.ThingManagerImpl.registerHandler(ThingManagerImpl.java:512) ~[?:?]
	at org.openhab.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:927) ~[?:?]
	at org.openhab.core.thing.internal.ThingManagerImpl.thingUpdated(ThingManagerImpl.java:475) ~[?:?]
	at org.openhab.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:234) ~[?:?]
	at org.openhab.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:145) ~[?:?]
	at org.openhab.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:325) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
	at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:66) ~[?:?]
	at org.openhab.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:91) ~[?:?]
	at org.openhab.core.model.thing.internal.GenericThingProvider.lambda$25(GenericThingProvider.java:940) ~[?:?]
	at java.util.ArrayList.forEach(ArrayList.java:1511) ~[?:?]
	at org.openhab.core.model.thing.internal.GenericThingProvider.createThingsFromModelForThingHandlerFactory(GenericThingProvider.java:948) ~[?:?]
	at org.openhab.core.model.thing.internal.GenericThingProvider.lambda$4(GenericThingProvider.java:308) ~[?:?]
	at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
	at org.openhab.core.model.thing.internal.GenericThingProvider.createThingsFromModel(GenericThingProvider.java:310) ~[?:?]
	at org.openhab.core.model.thing.internal.GenericThingProvider.modelChanged(GenericThingProvider.java:757) ~[?:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:298) ~[?:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:138) ~[?:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.checkPath(FolderObserver.java:255) ~[?:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:314) ~[?:?]
	at org.openhab.core.internal.service.WatchServiceImpl$Listener.notify(WatchServiceImpl.java:293) ~[?:?]
	at org.openhab.core.internal.service.WatchServiceImpl.lambda$6(WatchServiceImpl.java:278) ~[?:?]
	at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:?]
	at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179) ~[?:?]
	at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:992) ~[?:?]
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]
	at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
	at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
	at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596) ~[?:?]
	at org.openhab.core.internal.service.WatchServiceImpl.doNotify(WatchServiceImpl.java:278) ~[?:?]
	at org.openhab.core.internal.service.WatchServiceImpl.notifyListeners(WatchServiceImpl.java:271) ~[?:?]
	at org.openhab.core.internal.service.WatchServiceImpl.lambda$4(WatchServiceImpl.java:232) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
I checked the status of the AC in melcloud.com and can confirm its functional.
I am using a config via textfiles (I anonymized username, password and deviceID) with the following data that worked fine under OH3:
Bridge melcloud:melcloudaccount:myaccount "My MELCloud account" [ username="hhhhhhh", password="fffffffff", language="4" ] {
	Thing acdevice 			ac_living 			"Innengerät"	[ deviceID="22222222", pollingInterval=360 ]
and the items (although this doesn’t seem to be the problem):
Group				HeatpumpInside							"Wärmepumpe"
Switch				HeatpumpInsidePower               		"Betrieb [MAP(on.map):%s]" 				(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:power" }
String				HeatpumpInsideOperationMode       		"Modus [%s]" 							(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:operationMode" }
Number:Temperature	HeatpumpInsideSetTemperature      		"Zieltemp. [%.1f°C]" 					(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:setTemperature" }
String				HeatpumpInsideFanSpeed            		"Lüfter [%s]" 							(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:fanSpeed" }
String				HeatpumpInsideVaneHorizontal      		"Horizontal [%s]" 						(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:vaneHorizontal" }
String				HeatpumpInsideVaneVertical        		"Vertikal [%s]" 						(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:vaneVertical" }
Number:Temperature	HeatpumpInsideRoomTemperature     		"Raumtemp. [%.1f°C]" 					(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:roomTemperature" }
DateTime			HeatpumpInsideLastCommunication   		"Letzte Kom. [%1$tR, %1$tb %1$td]" 		(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:lastCommunication" }
DateTime			HeatpumpInsideNextCommunication   		"Nächste Kom. [%1$tR, %1$tb %1$td]" 	(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:nextCommunication" }
Switch				HeatpumpInsideOnline             		"Online [MAP(ja.map):%s]" 				(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:offline" }
Switch				HeatpumpInsideHasPendingCommand   		"Ausstehende Befehle [MAP(ja.map):%s]" 	(HeatpumpInside) 		{ channel="melcloud:acdevice:myaccount:ac_living:hasPendingCommand" }
Has someone any recommendations how to solve the problem?
I activated debugging and this is the output before the error occurs:
2024-09-04 09:23:47.600 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : ServiceFactory.getService()
2024-09-04 09:23:47.602 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : This thread collected dependencies
2024-09-04 09:23:47.604 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : getService (ServiceFactory) dependencies collected.
2024-09-04 09:23:47.605 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : Querying state active
2024-09-04 09:23:47.606 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-09-04 09:23:47.609 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2024-09-04 09:23:47.610 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : invoked activate: activate
2024-09-04 09:23:47.612 [DEBUG] [l.discovery.MelCloudDiscoveryService] - bundle org.openhab.binding.melcloud:4.2.1 (328)[org.openhab.binding.melcloud.internal.discovery.MelCloudDiscoveryService(438)] : Changed state from active to active
2024-09-04 09:23:47.617 [DEBUG] [l.discovery.MelCloudDiscoveryService] - Discover devices
Maybe this helps to find the reason.
Did you see this - did you try the latest JAR?
https://community.openhab.org/t/melcloud-binding-mitubishi/62199/127
There were some issues with the binding - maybe the fixed one solves your problem?
Yes, it seems to work fine.
Thanks for the hint - I missed it when searching for a solution
