Number Aral_G1 "Aral_G1" (gGasStations, gGasStations1,g2) {channel="tankerkoenig:station:WebserviceName:Aral:e5"}
Number Shell_G1 "Shell_G1 [%2.f]" (gGasStations, gGasStations1,g2) {channel="tankerkoenig:station:WebserviceName:Shell:e5"}
Number Aral_G2 "Aral_G2 [%3.f]" (gGasStations, gGasStations1,g2) {channel="tankerkoenig:station:WebserviceName:AralGK:e5"}
Number Star "Star [%3.f]" (gGasStations, gGasStations1,g2) {channel="tankerkoenig:station:WebserviceName:Star:e5"}
Number PM_G1 "PM_G1 [%.3f]" (gGasStations, gGasStations1,g2) {channel="tankerkoenig:station:WebserviceName:PM:e5"}
String CheapestGasStation "Cheapest Gas Station is [%s]"
By member of group, it should be sort by the cheapest:
rule "My cheapest gas station"
Item gGasStations changed
gGasStations.allMembers.forEach [ item |
if(item.state == gGasStations.state){
CheapestGasStation.sendCommand(item.label + " " + "€" + item.state.toString() )
That works.
But when i want to send this value to a TTS command, i hear the beginning of the first four values after each other for a second and at least the fifth value will be spoken complete. It reads the complete list and not the cheapest only i think.
rule "Tanken PM"
Item CheapestGasStation received update
if(now.getHourOfDay() >8 && now.getHourOfDay() <21){
Wohnzimmer_TTS.sendCommand('Hey!' + ',' + 'Die Spritpreise haben sich gerade geändert' + ',' + 'Die günstigste Tankstelle ist' + ',' + CheapestGasStation.state.toString() + 'Euro')
Another problem is that CheapestGasStation.state.toString() gives me the right label, but becaue of the string the price will be 1.509 (thousend) and not 1,509 Euro.
Any ideas?
Thanks and Greetings,
Markus
Hi Harry.
Oh, after updating to OH2.3 i haven’t check the locale. Right, i have set the wrong locale. Now changed.
But how can i change the rule, so that the cheapest price will be checked with the cheapest price before. If this is not equal, send it to TTS?
Thank you very much for helping,
Markus
I need the label of the item too. And the five items changes every hour at the same time. Can i use a thread::sleep in the TTS rule to get only the last change to the min value?
Greetings,
Markus
Group:Number:MIN gGasStations "Cheapest Gas Price[%.3f €]"
Number Aral_G1 "Aral_G1[%.3f]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Aral:e5"}
Number Shell_G1 "Shell_G1[%.3f]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Shell:e5"}
Number Aral_G2 "Aral_G2[%.3f]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:AralGK:e5"}
Number Star "Star[%.3f]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Star:e5"}
Number PM_G1 "PM_G1[%.3f]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:PM:e5"}
String CheapestGasStation "Cheapest Gas Station(s)[%s]"
String cgsDummy
Item gGasStations received update
cgsDummy.postUpdate("")
gGasStations.allMembers.forEach [ item | if (item.state == gGasStations.state) {
Thread::sleep(30)
if (cgsDummy.state == "") {cgsDummy.postUpdate(item.label)} else {cgsDummy.postUpdate(cgsDummy.state + "; " + item.label)}}]
CheapestGasStation.postUpdate(cgsDummy.state)
// logInfo("___", gGasStations.state.toString +" "+ CheapestGasStation.state)
Okay PM-G1 and Star have the same price. Is it possible to give both labels to the TTS command.
And after changing the local it still gives 1 thousand 4 houndred and 39. ?
I think (not knowing!) that is caused by the TTS service. You could prove that by changing the item to show only two decimal places, I would expect the TTS to say either 1 hundred and 39 or 1 thousend and 39 for 1.39.
Number Aral_G1 "Aral_G1[%.3f €]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Aral:e5"}
Number Shell_G1 "Shell_G1[%.3f €]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Shell:e5"}
Number Aral_G2 "Aral_G2[%.3f €]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:AralGK:e5"}
Number Star "Star[%.3f €]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:Star:e5"}
Number PM_G1 "PM_G1[%.3f €]" (gGasStations) {channel="tankerkoenig:station:WebserviceName:PM:e5"}
String CheapestGasStation "Cheapest Gas Station/s[%s]"
val StringBuilder sb = new StringBuilder
gGasStations.members.filter[ i | i.state == gGasStations.state].forEach[i | sb.append(", " + i.name) ]
CheapestGasStation.postUpdate(sb.substring(2))
// logInfo("***", String::format("%s %.3f Euro", CheapestGasStation.state, (gGasStations.state as DecimalType).floatValue))
// if(now.getHourOfDay() >8 && now.getHourOfDay() <21){Wohnzimmer_TTS.sendCommand(String::format("%s %.3f Euro", CheapestGasStation.state, (gGasStations.state as DecimalType).floatValue))}
Hi Harry.
It’s running beautiful. Thank you very much for your help and time.
I have changed %.3f to %.2f to get a correct value in Euro.
The only thing that happens is that the TTS command repeats for every change. And Alexa says by 5 changes to the same time: Hey,Hey,Hey,Hey,Hey, die Spritpreise haben sich geändert…
I will test it with a ‘,’ before the text, so in background it will fire the rule five times but you cannot hear it.
Thanks so much.
Greetings,
Markus
2018-07-04 10:36:44.483 [vent.ItemStateChangedEvent] - Star changed from 1.499 to 1.459
2018-07-04 10:36:44.483 [GroupItemStateChangedEvent] - gGasStations changed from 1.499 to 1.459 through Star
2018-07-04 10:36:44.692 [vent.ItemStateChangedEvent] - Hausserver_LastUpdated changed from 2018-07-04T10:36:34.691+0200 to 2018-07-04T10:36:44.691+0200
2018-07-04 10:36:44.693 [vent.ItemStateChangedEvent] - FlowerCare_LastUpdated changed from 2018-07-04T10:36:34.691+0200 to 2018-07-04T10:36:44.691+0200
2018-07-04 10:36:44.913 [vent.ItemStateChangedEvent] - Aral_G1_Update changed from 2018-07-04T09:36:53.733+0200 to 2018-07-04T10:36:44.911+0200
2018-07-04 10:36:44.913 [vent.ItemStateChangedEvent] - PM_G1_Update changed from 2018-07-04T09:36:53.633+0200 to 2018-07-04T10:36:44.911+0200
2018-07-04 10:36:44.915 [INFO ] [g.eclipse.smarthome.model.script.***] - Star 1,459 Euro
2018-07-04 10:36:44.916 [INFO ] [g.eclipse.smarthome.model.script.***] - Star 1,459 Euro
2018-07-04 10:36:44.916 [vent.ItemStateChangedEvent] - Shell_G1_Update changed from 2018-07-04T09:36:53.672+0200 to 2018-07-04T10:36:44.911+0200
2018-07-04 10:36:44.916 [vent.ItemStateChangedEvent] - Aral_G1_Update changed from 2018-07-04T09:36:53.685+0200 to 2018-07-04T10:36:44.911+0200
2018-07-04 10:36:44.918 [vent.ItemStateChangedEvent] - CheapestGasStation changed from Star, PM_G1 to Star
2018-07-04 10:36:44.918 [INFO ] [g.eclipse.smarthome.model.script.***] - Star 1,459 Euro
2018-07-04 10:36:44.925 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer_TTS' received command Star 1,459 Euro
2018-07-04 10:36:44.925 [vent.ItemStateChangedEvent] - Star_Update changed from 2018-07-04T09:36:53.656+0200 to 2018-07-04T10:36:44.917+0200
2018-07-04 10:36:44.926 [vent.ItemStateChangedEvent] - Wohnzimmer_TTS changed from to Star 1,459 Euro
2018-07-04 10:36:45.045 [INFO ] [g.eclipse.smarthome.model.script.***] - Star 1,459 Euro
2018-07-04 10:36:45.046 [INFO ] [g.eclipse.smarthome.model.script.***] - Star 1,459 Euro
There are again two commands to the TTS and Alexa will stutter.
include java.util.concurrent.locks.ReentrantLock
val ReentrantLock stompingLock = new ReentrantLock
rule ...
try {
stompingLock.lock()
} catch(Throwable t) { }
finally {
stompingLock.unlock()
