I am using Openhab Relase 5.1.4 and the Mercedes Me Binding from the market place. Installation on a QNAP NAS in a Container.
Problem: The Item Milage does not update. Only if I stop the container and restart again. Other items like batterie level, distance from homet,.. are working perfect.
mileage/odometer on the mb side often only moves when a trip ends, not on the same poll as battery / range. so it looking “stuck” while other channels update is pretty common.
things to check:
which channel you linked (odometer vs trip vs some computed item)
binding debug/trace for that vehicle around a real drive then park, see if a mileage payload even arrives
marketplace binding version vs 5.1.4, some builds only force a full vehicle status on init (that matches “updates after container restart”)
if debug shows no mileage until restart, it is on the binding/api side not your item config. posting a short debug slice from one drive cycle helps.
