Meross MSS210 firmware version 8.0.0 local MQTT
  • Platform information:
    • Hardware: x86_64/2Go/6Go
    • OS: ArchLinux uptodate
    • Java Runtime Environment: jre-openjdk 23.0.1.u
    • openHAB version: 4.2.3
  • Issue of the topic: problem to send a command to a Meross MSS210 switch with 8.0.0 firmware’s version
I have some issue with a new smart switch Meross MSS210.
I use a local MQTT mosquitto 2.0.18.
The device is configured with MerossBLE
I can read the status send by the device on my mosquitto server in /appliance/XXXX/publish topic.
I can sent an order to the device but it his status does not changed.
I had already do this with an older Meross device MSS620 without problem on the local mosquitto server and use it in OpenHAB.
      "hardware": {
        "type": "mss210",
        "subType": "un",
        "version": "8.0.0",
        "chipType": "rtl8720cf",
        "uuid": "XXXX",
        "macAddress": "XXXX"
      "firmware": {
        "version": "8.3.2",
        "compileTime": "2023/05/15-16:54:21",
        "encrypt": 1,
        "wifiMac": "XXXX",
        "innerIp": "XXXX",
        "server": "mosquitto_server",
        "port": 8883,
        "userId": XXX
Message sent for change the status in /appliance/XXXX/subscribe topic
  "header": {
    "messageId": "messsage1734084249927",
    "namespace": "Appliance.Control.ToggleX",
    "triggerSrc": "OpenHab",
    "method": "SET",
    "payloadVersion": 1,
    "from": "/appliance/openhab/ack",
    "uuid": "OpenHab server",
    "timestamp": 1734084249,
    "sign": "BC57E471020B7ADEFC948BB851C1F9FD"
  "payload": {
    "togglex": {
      "channel": 0,
      "onoff": 0
Do you have an idea to solve that ?
Thanks,
Ok, I think Meross added more security in their new firmwares, I give up :slight_smile:
I will return this product and will buy a more open device…
