Message but no image via pushover
Hey there,
I’m trying to transfer the image of the Pi Camera to my tablet via Pushover. I receive a message but no image. Here is my method:
I created this item:
Switch PiCam_Snapshot “PiCam Snapshot” {http=“>[ON:GET:http://192.168.188.131:8051/0/action/snapshot]”,expire=“10s,command=OFF”
After that i ceated the following rule:
var Timer CamFrontDoorbellSnapshotDelay = null
rule “Snapshot machen”
Item TFkontakt_optisch changed from CLOSED to OPEN
PiCam_Snapshot.sendCommand(ON)
rule “Sende Snapshot”
Item PiCam_Snapshot changed to ON
CamFrontDoorbellSnapshotDelay = createTimer(now.plusSeconds(1)) [ |
sendPushoverMessage(pushoverBuilder(“Besucher”).withAttachment(“/var/lib/motion/lastsnap.jpg”))
Does anybody know, what’s the problem? The path to the file should be correct.
Which oh Version?
Maybe this is related to Send Picture via Telegram not working - #5 by larshendrikkorte
the latest OH 2.3 version
Does anyboby have any idea or solution? :slight_smile:
Hey,
I have changed the title of your topic, since you wrote “pushbullet” there.
That was one reason for me not to look in here first, since i don’t use pushbullet :slight_smile:
About the problem:
Did you try to add
.withContentType("image/jpg")
(Just a quick shot.)
I can try to test it later at home with an image too.
Also it would be interesting to know if there are any logs which state an error.
And i am wondering if the path could be the reason.
Oh, thank you very much! :slight_smile:
Should i type this instead of .withAttachment or behind?
Thanks for your effort!
See Basic examples here: Pushover - Actions | openHAB
So behind of withAttachment.
Maybe Pushover recognizes that theres a picture attached then.
If you still have this problem I would play around with the 1 second timer - you might not be giving enough time to your Pi to take the picture and save it down before trying to send it to pushover.
Yetkin
