I wonder how can I be the first who noticed and write about this…
glad to help and be the first in something ahah
meteoblue gives windspeed data in meter per second but oh assumes it is in kmh if I use %unit%. If I use m/s it makes a conversion on the wrong assumption so it always show wrong data.
The wiki miss some available data in the example items file:
mean and felt temperature and other useful data.
I managed to obtain the mean temperature by guessing (just follow the mean humidity) but can’t do more because I have no experience on this kind of things.
proof os what I said is here: the raw data available is this:
“metadata”:
“name”: “Rome”,
“latitude”: xxx
“longitude”: xxx
“height”: 20,
“timezone_abbrevation”: “CET”,
“utc_timeoffset”: 1.00,
“modelrun_utc”: “2020-01-31T12:00+01:00”,
“modelrun_updatetime_utc”: “2020-01-31T19:18+01:00”
“units”:
“time”: “ISO8601”,
“predictability”: “percent”,
“precipitation_probability”: “percent”,
“pressure”: “hPa”,
“relativehumidity”: “percent”,
“co”: “ug/m3”,
“temperature”: “C”,
“winddirection”: “degree”,
“precipitation”: “mm”,
“windspeed”: “ms-1”
“data_day”:
“time”: [“2020-02-01”, “2020-02-02”, “2020-02-03”, “2020-02-04”, “2020-02-05”, “2020-02-06”, “2020-02-07”],
“pictocode”: [4, 4, 2, 12, 2, 1, 1],
“uvindex”: [1, 1, 2, 2, 2, 2, 2],
“temperature_max”: [14.95, 15.21, 17.71, 15.65, 13.37, 12.07, 12.45],
“temperature_min”: [10.46, 10.38, 9.03, 9.47, 2.68, 1.06, -0.74],
“temperature_mean”: [12.26, 12.17, 12.61, 12.33, 7.49, 5.30, 5.24],
“felttemperature_max”: [14.17, 14.45, 17.58, 12.91, 7.92, 6.30, 8.72],
“felttemperature_min”: [9.71, 9.66, 7.71, 4.65, -2.31, -4.15, -4.89],
“winddirection”: [225, 225, 270, 180, 0, 45, 45],
“precipitation_probability”: [16, 15, 0, 37, 16, 0, 0],
“rainspot”: [“0000000000000000000000000000000000000900000000000”, “0000000000000000000000000000000000000000000000000”, “0000000000000000000000000000000000000000000000000”, “0000001000009100000910001111000912299009220901222”, “0000000000000000000000000000000000000000000001112”, “0000000000000000000000000000000000000000000000000”, “0000000000000000000000000000000000000000000000000”],
“predictability_class”: [4, 4, 4, 3, 3, 4, 4],
“predictability”: [73, 79, 77, 40, 54, 66, 72],
“precipitation”: [0.00, 0.00, 0.00, 0.70, 0.00, 0.00, 0.00],
“snowfraction”: [0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.00],
“sealevelpressure_max”: [1022, 1022, 1021, 1019, 1021, 1036, 1037],
“sealevelpressure_min”: [1019, 1019, 1018, 1004, 1006, 1022, 1034],
“sealevelpressure_mean”: [1020, 1021, 1019, 1011, 1013, 1030, 1035],
“windspeed_max”: [1.69, 1.88, 1.20, 4.77, 5.10, 4.90, 2.28],
“windspeed_mean”: [1.02, 1.11, 0.91, 2.90, 3.57, 3.34, 1.59],
“windspeed_min”: [0.73, 0.71, 0.72, 0.75, 2.66, 1.67, 0.98],
“relativehumidity_max”: [95, 96, 96, 98, 61, 53, 69],
“relativehumidity_min”: [78, 76, 66, 56, 38, 34, 39],
“relativehumidity_mean”: [88, 88, 85, 86, 50, 45, 55],
“convective_precipitation”: [0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.00],
“precipitation_hours”: [0.00, 0.00, 0.00, 1.00, 0.00, 0.00, 0.00],
“humiditygreater90_hours”: [11.00, 12.00, 11.00, 11.00, 0.00, 0.00, 0.00]
by the way…I also have the missing icons problem and example only shows me today’s data…if some angel wish to help me I would really be an happy man
UPDATE1:
I found all the missing things in paper ui, but I also found 2 bridges, if I edit from the one of the bridges it returns error conflict 409. I just folowed wiki, I think it needs to be updated with more informations.
