Since the below block of code is kind of a method, which we can call in multiple places within the rule, what would be the syntax for a method without imput parameters?
var doTheMath = [ Integer i |
var integer = null
integer = i+i
return integer;
Test_Button changed
logInfo("test.rules","the math result is: " + doTheMath.apply(2))
//the above log print will be: "the math result is: 4"
Note, do not fall into the trap of thinking that a global lambda is the same as a method or a regular function. Lambdas are not thread safe and there is only one of them. This means that if two rules call a lambda at the same time, they will both be inside the same function and will stomp over each other as each run.
As a general rule, in Rules DSL, the creation of global lambdas like this is a code smell. It’s not automatically something wrong, but it is very likely that there is a much better and/or safer approach.
If you really want to use functions, than you should switch to Jython, JavaScript, or Groovy in the NGRE.
