Metrics Service with Influx 2.x
Hello all,
I am currently working on the Metric Services that openHAB offers as an addon, in addition to the normal persistence with Influx 2.x.
However, I am not getting any data pushed to the appropriate bucket in Influx. The configuration requires a user and password, but that is for Influx 1.x.
Does anyone know if it also works with Influx 2.x and how or where I should enter the token?
My openHAB environment is running on release 3.4 on a Ubuntu 22.04.1 LTS inside a proxmox VM.
Thanks for your help.
It’s all on the docs: InfluxDB (0.9 and newer) - Persistence Services | openHAB
@peterhoeg
I am not talking about the regular InfluxDB persistence services. This is setup properly and working fine with Influx 2.x.
I am talking about the Metrics services addon. Metrics service - System Integrations | openHAB
And is not all in the docs. It requires user+pass which is Influx 1.x auth but allows no entry of a token which is influx 2.x auth.
Ah, gotcha. Sorry, can’t help you there. I’m using prometheus for the metrics.
