Hey,
i`m runnin into troubles when i try to integrate my
Yeelight Stripe (Yeelight YLDD01YL) !
The stripe is discovered via the Mi IO Binding but the color channel is missing.
So i can only turn the Stripe On an OFF…no color-changes
This is what i get via Auto-Discovery
String XiaomiMiIOStripe_NetworkSsid "SSID" {channel="miio:basic:04CDB0C8:network#ssid"}
String XiaomiMiIOStripe_NetworkBssid "BSSID" {channel="miio:basic:04CDB0C8:network#bssid"}
Number XiaomiMiIOStripe_NetworkRssi "RSSI" {channel="miio:basic:04CDB0C8:network#rssi"}
Number XiaomiMiIOStripe_NetworkLife "Life" {channel="miio:basic:04CDB0C8:network#life"}
String XiaomiMiIOStripe_ActionsCommands "Execute Command" {channel="miio:basic:04CDB0C8:actions#commands"}
Switch XiaomiMiIOStripe_Power "Power" {channel="miio:basic:04CDB0C8:power"}
Number XiaomiMiIOStripe_Brightness "Brightness" {channel="miio:basic:04CDB0C8:brightness"}
Number XiaomiMiIOStripe_Delayoff "delayoff" {channel="miio:basic:04CDB0C8:delayoff"}
Number XiaomiMiIOStripe_ColorTemperature "Color Temperature" {channel="miio:basic:04CDB0C8:colorTemperature"}
Number XiaomiMiIOStripe_ColorMode "colorMode" {channel="miio:basic:04CDB0C8:colorMode"}
String XiaomiMiIOStripe_Name "Name" {channel="miio:basic:04CDB0C8:name"}
The toke is correct and i already resettet the Stripe and tried this a few times.
I was on Mi Io Stable and tried yesterday the latest Snapshot Build
I also have a Bulb (1st Gen) which runs flawlessly - the bulb comes out of the Box via Auto Discovery with the color-channel which is missing on my stripe
Color XiaomiMiIOBirne_Color "color" {channel="miio:basic:03362ADE:color"}
can someone help or explain what i`m doing wrong - or is this maybe a bug ?
