Mi(Xiaomi) Smart home bindings?
I upgraded my home server to OH2 a week ago. I guess I will start contributing to OH2.x version of this binding soon and retire my original binding for OH1.x :slight_smile:
Perfect thanks.
Is the plug86 the wifi plug?
Sadly no, it isn’t. All supported devices are Zigbee versions. (at least in OH1.x binding)
Hi, I like to thank you all for making this binding available. I so happy to use it on a powerfull automation system like openhab.
One thing which I discovered while trying the secound best open source platform( some call it home assistant) was that the gateway also has an illumination sensor.
I think is directional and therefore not very usefull, but can give an indication on if you have light in your room.
It’s just a nice to have function, but I like to make you all aware of this, if you didn’t know.
UPDATE:I discovered that I had some items configuation problems, my item was set to switch and not a number. :slight_smile:
Can i switch back to the snapshot version of this binding? I now use an older binding from end of june (manually copied to addons-folder) because the newer bindings didn“t work anymore.
I“m on OH2.2 snapshot.
Hi, just saw the new aqara motion sensors on gearbest.
Difference to the ā€œoldā€ motion sensor is the Holder Stand and now they have also a light intensity measurement. Seems to be a nice addition to the other sensors.
I have the mi gateway working with ohab2 like a charm. Can I turn the mi gateway alarm on ?
How did you install the binding? Is there any how-to to find regarding the configuration?
I installed the ohab2 snapshot that includes an add on binding for xiaomi smart home v2.2. It can controls devices connected to xiaomi gateway, but it could not find a channel to turn alarm on/off. Anny clue ?
How did you do that? I never updated/upgraded OH2 since i installed it. I’d like to upgrade to 2.1 and use xaiomi. Any hint?
The new water sensor is ready for pre-order. Discount with code GBCE.
I think the alarm is software based and you can program this by oursself
does anyone have a working smoke sensor on thier openhab system? I just bought one but it doen’t seems to work with my jar, org.openhab.binding.mihome-2.2.0-SNAPSHOT.jar with a size around 81.524 bytes
2017-07-25 17:26:36.772 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'mihome:smoke:158d000153948f' to inbox.
2017-07-25 17:26:36.777 [InboxAddedEvent           ] - Discovery Result with UID 'mihome:smoke:158d000153948f' has been added.
2017-07-25 17:29:34.518 [InboxRemovedEvent         ] - Discovery Result with UID 'mihome:smoke:158d000153948f' has been removed.
2017-07-25 17:29:34.528 [ThingAddedEvent           ] - Thing 'mihome:smoke:158d000153948f' has been added.
2017-07-25 17:29:34.534 [hingStatusInfoChangedEvent] - 'mihome:smoke:158d000153948f' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_REGISTERING_ERROR): XiaomiHandlerFactory could not create a handler for the thing 'mihome:smoke:158d000153948f'.
2017-07-25 17:29:34.522 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing handler factory 'org.openhab.binding.mihome.internal.XiaomiHandlerFactory@e72fca': XiaomiHandlerFactory could not create a handler for the thing 'mihome:smoke:158d000153948f'.
java.lang.IllegalStateException: XiaomiHandlerFactory could not create a handler for the thing 'mihome:smoke:158d000153948f'.
Hi All,
Thanks a lot for your effort and the binding.
I am using OH2 for quite some time for my KNX installation and recently started to introduce Xiaomi products.
I recently bought the Xiaomi Philips Bulb and I am wondering if and how I can integrate to OH2.
  • Can you give me some hints on what I can do to figure which protocol is used and how I may integrate it to the binding?
Thanks,
OvO
Not sure about this Xiaomi Philips Bulb. The MiHome binding supports the ZigBee-based devices from Xiaomi.
If you’re interested in e.g. Yeelight bulbs/LED stripes, check out this pull request. I hope that @coasterli or someone else will finish the work on it eventually.
I’m using this binding for Yeelight RGBW as well as the white ones.
Cheers,
Kuba
Hi all,
currently I’m concentrating my energy into addig Miio protocol support to this OH2 binding so other devices might be discovered and controlled in openHAB (vacuum robot, air purifier and other wifi devices - as you do in mi home mobile app). Getting device tokens is a bit tricky and must be done manually, but it’s worth having all device’s control at one place - openHAB.
I hope it will be ready soon - :grinning:
@Ondrej_Pecta that’s awesome! Looking forward to see and test your progress.
Note that @marcel_verpaalen is working on the Xiaomi Vacuum Binding as well. You might want to cooperate on this :slight_smile:
Cheers!
Really cool if we can directly interact with Miio protocol. It should simplify integration of other devices.
I guess that the bulb I bought are using this Miio protocol.
If you need help or info on teh bulb just let me know.
Based on what I read on another implementation for the vacuum, I think you actually can already control other devices like the powerplug & fan with the current vacuum binding.
There is the command channel which allow for any miio command to be send. the fan/light/whatever other device would probably be discovered as a vacuum, but if you allow that, and send commands.
(e.g. get fan status with get_prop, set the humidity with set_limit_hum) I guess it works.
Probably you need to set the refresh interval to something high, as I think a powerplug or a fan don’t support the vacuum commands, and would indicate that It can’t communicate.
Try if it works, in that case I don’t mind to see if those can be supported as well.
An alternative would be to bring it into the mi smarthome binding, but as the interfacing & crypto seemed quite different I started clean.
My suggestion would be to only integrate it if there can be substantial pieces of code shared, otherwise it is easier and less complex to keep them separated .
