My Miele bridge gets regularly a different IP address from the server. Surely I can change the IP number in the .things file, however it should be possible to use the local name, as I can do it with my Hue Bridge. If I try the following:
The initalizer of the Miele binding throws the following error:
2019-01-08 22:21:17.303 [hingStatusInfoChangedEvent] - 'miele:xgw3000:Miele_XGW3000' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Invalid IP address for the Miele@Home gateway or multicast interface:Miele-0023D5C667B8.local/192.168.0.17
The address Miele-0023D5C667B8.local is definately valid as I can ping to it in the linux console. Any idea how to circumvent this problem? As I wrote the Hue binding allows to use local names.
Thank you @vzorglub. That indeed solves my problem.
However, it would still be better to have it work directly… I will check that in the sources and see if I can solve it.
