I see that your Miele binding is based on a gateway device which then communicates with the appliances using the Zigbee protocol.
The dishwasher I’m getting here in the US appears to use WiFi for it’s communications with the Miele smartphone app – the so-called Miele WiFi Conn@ct technology. I’m curious if you know whether the high level protocol is the same across the two different comm layers. Wondering how easy it would be to adapt the binding for the models that use Wifi.
Or, if you know whether Miele publishes the protocol. I’ve not been able to find any documentation on it.
Thanks!
