Hi all,
Ive been using the Mios Binding for ages ( no long after it was created iirc! ) to link OH to my Vera Lite.
All works pretty well although sometimes some devices take longer than id like to respond…most of the time its ok, just sometimes…and i suspect Vera is the cause of the delay as such ive been thinking of moving off of the Vera and use the Aeon Z Stick i have in my ‘box-o-bits’!
My Z Wave network only really consists of 20+ in-wall modules ( switch and dimmers ) and a few plug-in switches.
I’d like to not have to open up the walls to re-pair the modules with the z-stick and from what i’ve read/understand, i should be able to add the Z stick as a “secondary/slave controller” and once up and running OH using the Z Stick remove the Vera as PRI controller and make the Z Stick the PRI controller…
As for Items/Things - i expect i can comment out my existing items using the MIOS binding and replace them with the Thing channels…and thus have zero downtime…?
OK thanks…
I guess first step is to add this Zstick to the existing Zwave network.
I grabbed a copy of the Zensys Tools which seems to have the functionality to do this.
