finally found some time to make my first experience with openhab2 binding development.
I migrated the meter binding available in openhab 1 to openhab 2.
I heard that some users of the openhab1 binding were asking to get support for this binding in openhab2. Here now the first try…
The new binding can be fully configured with the PaperUI.
As the channels will vary from meter to meter the thing initializing will created the obis response from the meter as channels.
Download available here: binding download
If there are some tester here in the community could verfiy the binding, would appreciate your feedback.
If feedback is good I would like to issue a pull request in a few week from now.
yes , i am also using the IR from Udo, seems that we have supplied the same equipment :-).
unfortunately below link is in german but it states that the meter has implemented 62056-21
i see that the meter speaks sml , not sure if this is going to work
looking at the openmuc frauenhofer page , a lot of changes have been done on the code base which i started to use in 2014. so it may make sense to maybe reconsider to take a new step using there libraries.
license is gpl 2.1 and 3.0 (sml)
i acutally have only test the paperUI interface to configure the thing and get the channels / items of the meter
main idea was to keep it as simple as possible.
i have not tested how to do this manually.
Will try to do this later on and will also provide that describtion in the final pull request.
it should like this… to be tested
item definition
String test “meter type [%s]” { channel=“iec6205621meter:meter:mymeter:meterType” }
could you try this library jSML | OpenMUC
with the serial readerwith your meter.
If you receive data we could add this as a new meter type into the binding or create a new binding for sml
no need to use mincom.
The link i send is a command line tool which gets the data from the meter in case it speaks SML.
the command line is described in the download and called SampleSerialRead with the parameter of the serial interface
It is also java library which we could easily integrate in the exisitng binding as a new metertype
So if your test would be sucessful i could integrate it
On your link i get a tar-file. Don´t know what i have to do with this. But i don´t want to install something just for testing on my working openhab server.
I can say to you, that the ehm ehz power meter speaks sml. You can find many posts on the internet. But you only get few values out of the power meter, no voltage or historical data. Only kwh and watt.
In my current installation it works with the c-script, which reads out the data from the power meter and parses the smsl-data to readable values. See my links absove. It was a little bit tricky to get it running, so i don´t want to crash my system with much testing of other posibilites… I have an esxi-server and the usb-ir-readers are pass-through to my virtual machine. It was a long way to get this working properly.
Maybe @binderth can help you, he is a more advised user with the same power meter.
well the sml library from frauenhofer will not interfer with openhab and shoudl the same as your c programm.
It would be good for me to get somebody testing if the library works with the sml meter.
If it would work i could add a new thingtype in the existing library, to get the sml supported based on this library
the binding has not implemented sml today.
if the library reader is working with the ehz meter i could integrate the library into the existing binding.
So please use the archive file from openmuc, start the reader from their archive and verify if you receive sml messages. here is what the openmuc libray states to run the reader from commandline
Using the examples:
For an example on how to use jSML see the folder src/sample/java/ .
You can create Eclipse project files as explained here: http://www.openmuc.org/index.php?id=28 and run the sample from within
Eclipse or you can compile and execute it in a terminal. To compile
and execute the sample on Linux use something like this:
go to the folder src/sample/java/
javac *.java -cp “../../../build/libsdeps/jsml-.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar”
java -cp “../../../build/libsdeps/jsml-.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar:./” SampleSerialRead
or run SampleSMLServer or SampleSMLClient instead of SampleSerialRead
To execute the server and client in ssl mode:
java -Djavax.net.ssl.keyStore=/path/to/serverKeystore -Djavax.net.ssl.keyStorePassword=“storepass” -cp “../../../build/libsdeps/jsml-.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar:./” SampleSMLServer -s
java -cp “../../../build/libsdeps/jsml-.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar:./” SampleSMLClient -s
tried to compile javac *.java -cp "../../../build/libsdeps/jsml-.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar"
got those errors:
SampleSerialRead.java:28: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.ASNObject;
SampleSerialRead.java:29: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.Integer32;
SampleSerialRead.java:30: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.Integer64;
SampleSerialRead.java:31: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.OctetString;
SampleSerialRead.java:32: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_File;
SampleSerialRead.java:33: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_GetListRes;
SampleSerialRead.java:34: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_List;
SampleSerialRead.java:35: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_ListEntry;
SampleSerialRead.java:36: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_Message;
SampleSerialRead.java:37: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_MessageBody;
SampleSerialRead.java:38: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_PublicOpenReq;
SampleSerialRead.java:39: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_Value;
SampleSerialRead.java:40: error: package org.openmuc.jsml.tl does not exist
import org.openmuc.jsml.tl.SML_SerialReceiver;
SampleSMLClient.java:31: error: package org.openmuc.jsml.structures does not exist
SampleSMLClient.java:32: error: package org.openmuc.jsml.structures does not exist
SampleSMLClient.java:33: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_GetProfileListReq;
SampleSMLClient.java:34: error: package org.openmuc.jsml.structures does not exist
SampleSMLClient.java:35: error: package org.openmuc.jsml.structures does not exist
SampleSMLClient.java:36: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_PublicCloseReq;
SampleSMLClient.java:37: error: package org.openmuc.jsml.structures does not exist
SampleSMLClient.java:38: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.SML_TreePath;
SampleSMLClient.java:39: error: package org.openmuc.jsml.structures does not exist
import org.openmuc.jsml.structures.Unsigned8;
SampleSMLClient.java:40: error: package org.openmuc.jsml.tl does not exist
import org.openmuc.jsml.tl.SML_TConnection;
SampleSMLClient.java:41: error: package org.openmuc.jsml.tl does not exist
import org.openmuc.jsml.tl.SML_TSAP;
SampleSMLServer.java:29: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:30: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:31: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:32: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:33: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:34: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:35: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:36: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:37: error: package org.openmuc.jsml.structures does not exist
SampleSMLServer.java:38: error: package org.openmuc.jsml.tl does not exist
SampleSMLServer.java:39: error: package org.openmuc.jsml.tl does not exist
import org.openmuc.jsml.tl.SML_TConnectionListener;
SampleSMLServer.java:40: error: package org.openmuc.jsml.tl does not exist
SampleSMLServer.java:42: error: cannot find symbol
public class SampleSMLServer implements SML_TConnectionListener {
symbol: class SML_TConnectionListener
SampleSMLServer.java:98: error: cannot find symbol
public void connectionIndication(SML_TConnection smlTConnection) {
SampleSerialRead.java:45: error: cannot find symbol
SML_SerialReceiver receiver = new SML_SerialReceiver();
symbol: class SML_SerialReceiver
SampleSerialRead.java:50: error: cannot find symbol
SML_File smlFile = receiver.getSMLFile();
symbol: class SML_File
SampleSerialRead.java:53: error: cannot find symbol
List<SML_Message> smlMessages = smlFile.getMessages();
symbol: class SML_Message
SampleSerialRead.java:59: error: cannot find symbol
SML_Message sml_message = smlMessages.get(i);
SampleSerialRead.java:63: error: cannot find symbol
case SML_MessageBody.OpenRequest:
symbol: variable SML_MessageBody
SampleSerialRead.java:64: error: cannot find symbol
SML_PublicOpenReq sml_PublicOpenReq = (SML_PublicOpenReq) sml_message.getMessageBody().getChoice();
symbol: class SML_PublicOpenReq
SampleSerialRead.java:68: error: cannot find symbol
case SML_MessageBody.OpenResponse:
SampleSerialRead.java:71: error: cannot find symbol
case SML_MessageBody.CloseRequest:
SampleSerialRead.java:74: error: cannot find symbol
case SML_MessageBody.CloseResponse:
SampleSerialRead.java:77: error: cannot find symbol
case SML_MessageBody.GetProfilePackRequest:
SampleSerialRead.java:80: error: cannot find symbol
case SML_MessageBody.GetProfilePackResponse:
SampleSerialRead.java:83: error: cannot find symbol
case SML_MessageBody.GetProfileListRequest:
SampleSerialRead.java:86: error: cannot find symbol
case SML_MessageBody.GetProfileListResponse:
SampleSerialRead.java:89: error: cannot find symbol
case SML_MessageBody.GetProcParameterRequest:
SampleSerialRead.java:92: error: cannot find symbol
case SML_MessageBody.GetProcParameterResponse:
SampleSerialRead.java:95: error: cannot find symbol
case SML_MessageBody.SetProcParameterRequest:
SampleSerialRead.java:98: error: cannot find symbol
case SML_MessageBody.GetListRequest:
SampleSerialRead.java:101: error: cannot find symbol
case SML_MessageBody.GetListResponse:
SampleSerialRead.java:102: error: cannot find symbol
SML_GetListRes resp = (SML_GetListRes) sml_message.getMessageBody().getChoice();
symbol: class SML_GetListRes
SampleSerialRead.java:103: error: cannot find symbol
SML_List smlList = resp.getValList();
symbol: class SML_List
SampleSerialRead.java:107: error: cannot find symbol
SML_ListEntry[] list = smlList.getValListEntry();
symbol: class SML_ListEntry
SampleSerialRead.java:109: error: cannot find symbol
for (SML_ListEntry entry : list) {
SampleSerialRead.java:112: error: cannot find symbol
SML_Value value = entry.getValue();
symbol: class SML_Value
SampleSerialRead.java:113: error: cannot find symbol
ASNObject obj = value.getChoice();
symbol: class ASNObject
SampleSerialRead.java:115: error: cannot find symbol
if (obj.getClass().equals(Integer32.class)) {
symbol: class Integer32
SampleSerialRead.java:116: error: cannot find symbol
Integer32 val = (Integer32) obj;
SampleSerialRead.java:119: error: cannot find symbol
else if (obj.getClass().equals(Integer64.class)) {
symbol: class Integer64
SampleSerialRead.java:120: error: cannot find symbol
Integer64 val = (Integer64) obj;
SampleSerialRead.java:123: error: cannot find symbol
else if (obj.getClass().equals(OctetString.class)) {
symbol: class OctetString
SampleSerialRead.java:124: error: cannot find symbol
OctetString strVal = (OctetString) obj;
SampleSerialRead.java:133: error: cannot find symbol
case SML_MessageBody.AttentionResponse:
SampleSMLClient.java:73: error: cannot find symbol
SML_TSAP sml_tSAP = null;
symbol: class SML_TSAP
SampleSMLClient.java:75: error: cannot find symbol
sml_tSAP = new SML_TSAP();
SampleSMLClient.java:84: error: cannot find symbol
sml_tSAP = new SML_TSAP(sslSocketFactory);
SampleSMLClient.java:87: error: cannot find symbol
SML_TConnection sml_tConnection = null;
SampleSMLClient.java:96: error: cannot find symbol
SML_File sml_File = sml_tConnection.receive();
SampleSMLClient.java:100: error: cannot find symbol
List<SML_Message> sml_messages = sml_File.getMessages();
SampleSMLClient.java:101: error: cannot find symbol
for (SML_Message sml_message : sml_messages) {
SampleSMLClient.java:104: error: cannot find symbol
SampleSMLClient.java:105: error: cannot find symbol
SampleSMLClient.java:109: error: cannot find symbol
SampleSMLClient.java:112: error: cannot find symbol
SampleSMLClient.java:115: error: cannot find symbol
SampleSMLClient.java:118: error: cannot find symbol
SampleSMLClient.java:121: error: cannot find symbol
SampleSMLClient.java:124: error: cannot find symbol
SampleSMLClient.java:127: error: cannot find symbol
SampleSMLClient.java:130: error: cannot find symbol
SampleSMLClient.java:133: error: cannot find symbol
SampleSMLClient.java:136: error: cannot find symbol
SampleSMLClient.java:139: error: cannot find symbol
SampleSMLClient.java:142: error: cannot find symbol
SampleSMLClient.java:145: error: cannot find symbol
SampleSMLClient.java:175: error: cannot find symbol
OctetString transactionId = new OctetString(("" + transactionIDCounter++).getBytes());
Note: XTrustProvider.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
100 errors
do I miss some package? running Oracle JAVA8 JDK on RPI:
pi@raspberrypi:~/openMuc/jsml/src/sample/java $ java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
after that you should see a SampleSerialRead.java file
java -cp “../../../build/libsdeps/jsml-1.0.17.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar:./” SampleSerialRead
if rxtxSerial is missing you need to install it via apt
ok, got the compiling done now - thanks!
I searched for some rxtx packages, only came up with sudo apt-get install librxtx-java, after installing that, the same error is present:
pi@raspberrypi:~/jsml/src/sample/java $ java -cp "../../../build/libsdeps/jsml-1.0.17.jar:../../../dependencies/rxtxcomm_api-2.2pre2-11_bundle.jar:./" SampleSerialRead
java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path thrown while loading gnu.io.RXTXCommDriver
Exception in thread "main" java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:123)
at org.openmuc.jsml.tl.SML_SerialReceiver.setupComPort(SML_SerialReceiver.java:56)
at SampleSerialRead.main(SampleSerialRead.java:46)
Hi Peter,
1st of all: appreciate very much your hard work on creating a binding for OH2!
I used to successfully read my Landis E350 meter under OH1 with the old binding using an IR head with USB interface.
Without any changes on my RPi setup (besides migrating from OH1 to OH2), I tried to get your new binding working, but I’m struggling with a very basic error:
“Failed to open serial port /dev/ttyUSB0: Serial port with given name does not exist”
Checking via “$ ls -l /dev/serial/{by-path,by-id}/*” or “/sbin/udevadm info --query=all --name=/dev/ttyUSB0” shows that the IR head is all fine:
nothing is hardcoded when it comes to the port to be used.
just handing over to as in OH1 to the same library. very strange.
Is the bundle in DEBUG mode?
In case not please please use the karaf console to set it to debug and see if there is more info in the log. here the commands to issue , passworfd should be “habopen”
According to the implementation this is an IOException from the nrjavaserial library inside OH2.
Does the user in which OH2 is running having proper access rights to port?
I uploaded a new version which adds some more info during looging the error
in below example i add the evailable ports
21:10:39.245 [ERROR] [meter.handler.Iec6205621MeterHandler] - Failed to open serial port /dev/ttyS1: Serial port with given name does not exist. :/dev/ttyS5:/dev/ttyS4:/dev/ttyS0
21:10:39.245 [ERROR] [meter.handler.Iec6205621MeterHandler] - Could not get data from IEC 62056-21 meter connected to /dev/ttyS1
In case the USB ports are not showing it maybe an issue with rxtx port issue
